MSXML2.ServerXMLHTTP.6.0
  • Remote Operations
  • MSXML2.ServerXMLHTTP.6.0
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
DavidSkilbeck
Lt. Commander DavidSkilbeck
Lt. Commander
Posted: ‎2021-07-16 02:09 AM . Last Modified: ‎2023-05-03 12:02 AM
10535
I am using "MSXML2.ServerXMLHTTP.6.0." within Geo SCADA VBScript.
Where can I find documentation on "MSXML2.ServerXMLHTTP.6.0." specifically for Geo SCADA VBS please.
I cant remember if I was using option 2 or three or the syntax.
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
DavidSkilbeck
Lt. Commander
Posted: ‎2021-07-18 03:44 PM
In response to BevanWeiss
10496
I only attached part snippet.
All done now.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 5
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-07-16 08:26 PM
4
10511
"Specifically for Geo SCADA VBS" is not a thing.
The Geo SCADA Expert ViewX scripting uses the Microsoft Active Scripting engine.  So this aspect is not a Schneider / Geo SCADA Expert specific thing.
The Server... etc objects are Geo SCADA Expert specific, but Microsoft's MSXML2 is NOT.
For documentation around the MSXML2 object you would need to consult Microsoft documentation.
A quick google brings up this:
https://docs.microsoft.com/en-us/previous-versions/windows/desktop/ms766431(v=vs.85)
Which has some code (although it looks like MS only show JScript here, not VBScript... but JScript is also an ActiveScript language... so you could just use JScript instead of VBScript).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DavidSkilbeck
Lt. Commander
Posted: ‎2021-07-17 12:56 AM
10507
Hi, with reference to the below code. I tried a number of variations on the fourth line yesterday (Proxy Option). But I couldn't find the right one.
I am sure I saw it working two weeks back. I hope I did.
Thanks, David.
    Set objO = CreateObject("MSXML2.ServerXMLHTTP.6.0")
    'Encode the username and password here
    strUserPass = base64_Encode(strUserName+":"+strPassword)
    objO.setOption 2, https://proxy.xx.xxxxxxxxxxx.xxxxxxxx, "8080"
    objO.setOption 3, ""
    objO.setTimeouts 10000, 10000, 10000, 10000
    objO.open "POST", strURL, False
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-07-17 09:30 PM
In response to DavidSkilbeck
10503
I think that given none of this is Geo SCADA Expert specific (it's all just VBScript and Microsoft core libraries) you will be better off on something like Stack Overflow for it.
I do note that the code sample you've provided has numerous syntactical errors... so you might want to fix these, along with aligning your existing code structure closer to the Microsoft examples.. e.g.
For GET
var objSrvHTTP;
objSrvHTTP = Server.CreateObject ("Msxml2.ServerXMLHTTP.6.0");
objSrvHTTP.open ("GET","http://someotherserver/respond.asp", false);
objSrvHTTP.send ();
Response.ContentType = "text/xml";
Response.Write (objSrvHTTP.responseXML.xml);
or for POST with an XML body
var objSrvHTTP;
var objXMLDocument;
objXMLDocument = Server.CreateObject ("Msxml2.DOMDocument.6.0");
objXMLDocument.async= false;
objXMLDocument.loadXML ("<msg><id>1</id></msg>");
objSrvHTTP.open ("POST","http://someotherserver/respond.asp",false);
objSrvHTTP.send (objXMLDocument);
If you are indeed trying to set the Proxy options, then setProxy seems like the more appropriate method
https://docs.microsoft.com/en-us/previous-versions/windows/desktop/ms760236(v=vs.85)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DavidSkilbeck
Lt. Commander
10497
All done now.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-07-19 08:55 PM
Perhaps you could add some more detail on what the actual solution was.
Your selected 'solution' appears to contain no details, so it wouldn't be at all helpful to anyone else.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
