Share Your Feedback โ€“ Help Us Improve Search on Community!
Incorrect Help documentation for Active Deadband Setup in x70 outstation configuration form
Showing results forย
Did you mean:ย
  • Remote Operations
  • Incorrect Help documentation for Active Deadband Setup in x70 outstation configuration form
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxureโ„ข Geo SCADA Expert
RemoteConnect for the SCADAPack x70
rlao
Lt. Commander rlao
Lt. Commander
Posted: โ€Ž2023-04-21 12:41 AM . Last Modified: โ€Ž2023-05-02 11:44 PM
1565
In the x70 outstation configuration object in Geo SCADA 2020, there is an active deadband setup configuration item:
The tooltip did not make it clear whether I was meant to check or uncheck the box to withhold Class 0 poll responses during an active time deadband. When I was going through the Geo SCADA help, I noticed that this item has a different description in all Geo SCADA versions of the help files, e.g. 2020 help and 2022 help. It is called 'Filter Class 0 Data' and mentions that ticking the checkbox withholds Class 0 data during an active deadband timer.
When I go onto RemoteConnect, the setting description matches what I see in my version of Geo SCADA ('Always Include Time Deadband in Class 0'). Furthermore, it specifically says that unticking the checkbox will withhold Class 0 data during the active time deadband.
Base on my testing, it looks like the Geo SCADA help documentation is incorrect and that the x70 SCADAPack follows what is described in RemoteConnect, i.e. you need to untick this for Class 0 data to be withheld. This was done specifically on a 470.
Is it possible for this to be fixed so that in future others can avoid the same confusion that I went through today?
  • DNP3
  • Drivers
  • RTU
  • SCADA
  • Telemetry
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: โ€Ž2023-04-25 03:45 AM
1532
Thank you very much, and sorry you found this the hard way. Doc update will be coming.
Replies 4
sbeadle
Kirk sbeadle Kirk
Kirk
1533
rlao
Lt. Commander rlao
Lt. Commander
Posted: โ€Ž2023-04-25 07:43 PM
In response to sbeadle
Thanks, much appreciated ๐Ÿ‘
SMountain
SMountain
Cadet
Posted: โ€Ž2023-05-12 03:45 AM
1480
Thank you for pointing this out. The Geo SCADA Expert documentation has now been updated. The update will be available in the help in Geo SCADA Expert 2023/V86. We intend backporting the documentation update so that it will be available in a future Monthly Update of other supported versions of Geo SCADA Expert.
rlao
Lt. Commander rlao
Lt. Commander
Posted: โ€Ž2023-05-15 12:16 AM
In response to SMountain
Thanks for update on this one, much appreciated
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
