[Imported] WebX Hand Control "not well-formed (invalid token)" error
  • Remote Operations
  • [Imported] WebX Hand Control "not well-formed (invalid token)" error
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
115
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:21 AM . Last Modified: ‎2023-05-03 12:30 AM
858
User: tcookson, originally posted: 2018-11-13 17:35:20 Id:317
I'm having an issue similar to, but not exactly like, the one described here: https://www.schneider-electric.us/en/faqs/FA275742/
If I follow the the FAQ note and add port 81, then mimics no longer display. In my case alarms/events/mimics all display correctly, but when I Hand Control a test internal point through WebX I get an error pop-up "not well-formed (invalid token)". WebX has control privileges in the web test folder, including the mimic I'm writing from and the point I'm trying to hand control.
System is ClearSCADA 2017 (Sept '17 update), running on Windows Server 2012.
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:21 AM . Last Modified: ‎2019-11-06 02:29 AM
Reply From User: BevanWeiss, posted: 2019-01-03 21:59:34
Why would you change this from port 80 to port 81?
What port numbers (HTTP/HTTPS) is your WebX using?
NOTE: The FAQ is for "A common cause of these errors is the Original WebX being configured to use custom secure or non-secure ports". If you are not using 'custom secure or non-secure ports' then you should not have followed the directions in your link.
Reply From User: geoffpatton, posted: 2019-01-04 14:56:00
check the server configuration's WebX section and make sure Allow writes over HTTP is checked.
Reply From User: tcookson, posted: 2019-04-02 23:37:33
The check box states "Allow logon and database writes over ****non-secure ****HTTP.
I'd much prefer HTTPS, if possible.
Reply From User: sbeadle, posted: 2019-04-03 08:05:28
Client to web server communications are either HTTP or HTTPS, as configured within IIS. Web Server to ClearSCADA server communications are also configurable using HTTP or HTTPS, as configured in the IIS settings (referred in the FAQ) and Server Config tool WebX settings combined.
You can check the ClearSCADA server web port comms by enabling the WebX logging types in Server Status and reading the dbserver log files.
Reply From User: adamwoodland, posted: 2019-04-04 01:27:38
https://tprojects.schneider-electric.com/telemetry/display/CS/Diagnosing+Scripting+Connection+Errors may also help with your problem
sbeadle
Kirk sbeadle Kirk
Kirk
