[Imported] Template Repository
  • Remote Operations
  • [Imported] Template Repository
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-26 01:39 PM . Last Modified: ‎2023-05-03 12:22 AM
1066
User: cmrl, originally posted: 2019-08-02 08:48:19 Id:480
Dear ClearSCADA Users,
This is just an idea, I don't know whether such thing exists - but what about having a repository where we can share tested component templates?
Greetings from Berlin
Mauricio
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-26 01:40 PM
Reply From User: geoffpatton, posted: 2019-08-02 16:17:32
For my company, our templates are considered proprietary.
Reply From User: dmercer, posted: 2019-08-05 01:26:34
I'd be interested in helping if I can, but I don't think that it would be appropriate for me to share anything that I have from work either,
Reply From User: BevanWeiss, posted: 2019-08-06 03:00:32
It is tricky to do in commercial enterprise, after all, significant expense has typically gone into developing such 'tested component templates'.
I also think that it would have limited application, since most applications will be slightly different, and hence will have a slightly different set of requirements, meaning that the existing component template is not a good fit.
You should see how many different variants of a sewer pump station there are in the world... it's really just a well which collects 'stuff', and a set of pumps to pump it out... but even within a single waste water organisation there will be at least a dozen variants. I know of some authorities that have several hundred pump stations, and every single one is slightly different...
Reply From User: hardin4019, posted: 2019-08-07 13:31:02
Agreed, it would be a nice thing to have, also agree that it will be nearly impossible for most to share their work since it would be considered the intellectual property of their employers.
Reply From User: du5tin, posted: 2019-09-27 14:04:55
We have had some discussion over here about putting together an open source set of templates and such, primarily for oil and gas. I think the idea has potential and will become more prevalent in time.
Is this something you would like SE to host? Or to put on github or similar code sharing platform?
Reply From User: BevanWeiss, posted: 2019-09-28 00:28:21
If there was a Github repository (ideally hosted by SE) which people contributed into, then I think it could be easier to get some traction on donating also (at least making some improvement contributions back to it).
Reply From User: adamwoodland, posted: 2019-09-29 22:49:42
Steve would probably be over the moon if people contributed to https://github.com/clearscada
Reply From User: sbeadle, posted: 2019-10-10 10:37:24
Absolutely! I'll be adding more samples of code to it, but there's no reason we can't add .sde files as well.
sbeadle
Kirk sbeadle Kirk
Kirk
