[Imported] Stuck on sql code
Send InviteCancel
Posted: 2019-11-0612:27 PM. Last Modified: 2023-05-0312:27 AM
>>Message imported from previous forum - Category:General Items<< User: ROVSCADAENGINEER, originally posted: 2019-02-20 22:40:26 Id:369 Ok so I am stuck on some SQL code as I am trying to write to the registry a name for the embedded list on the mimic so I can edit the filters on the list through click buttons. the code which is working on the query option is below:
SELECT RECORDTIME, SEVERITY, SOURCE, MESSAGE, USER, CATEGORY, FOREGROUND, SEQNO, COMMENTNO, ID FROM CDBEVENTJOURNAL WHERE SOURCE LIKE '%Overflow Float%' AND ( RECORDTIME BETWEEN { OPC 'H-10D' } AND { OPC 'H' } ) AND SEVERITY = 'Critical'
Yet the code that I put in the animation sql expression is similar to another working code on another embedded list yet does not work. can anyone see where I may be going wrong. scada keeps saying that ) is expected. yet I cannot figure it out.
'SELECT RecordId, SeverityDesc, RecordTime, Message, User, Category, Foreground, SeqNo, CommentNo,id FROM CDBEVENTJOURNAL '+ REGISTRY( 'OverflowFloatsList', 'WHERE source LIKE '%Overflow Float%' and ( RecordTime BETWEEN { OPC ''H-24H'' } AND { OPC ''H'' } )') and SEVERITY = 'Critical'
I am going to try the code in query pad and see if I get a more particular analysis.
Posted: 2019-11-0612:28 PM
Reply From User: ROVSCADAENGINEER, posted: 2019-02-20 23:34:00 I got it working
'SELECT RECORDTIME, SEVERITY, SOURCE, MESSAGE, USER, CATEGORY, FOREGROUND, SEQNO, COMMENTNO, ID FROM CDBEVENTJOURNAL '+ REGISTRY( 'smsLists', ' WHERE SOURCE LIKE ''%Overflow Float%'' AND ( RECORDTIME BETWEEN { OPC ''H-10D'' } AND { OPC ''H'' } ) AND SEVERITY = ''Critical'')')
Reply From User: du5tin, posted: 2019-03-06 17:07:00 Yeah... escape characters are definitely needed for animations. :smiley:
