[Imported] SQL Commands to extract rows from Data Table in ST
  • Remote Operations
  • [Imported] SQL Commands to extract rows from Data Table in ST
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-26 02:09 PM . Last Modified: ‎2023-05-03 12:21 AM
1086
>>Message imported from previous forum - Category:Scripts and Tips<<
User: hemanth, originally posted: 2019-10-08 11:28:11 Id:534
I have created a data table [TEST1_TABLE] in clearscada with Index1,val1,val2 all INT type.
Inserted few rows using INSERT command.
Is it possible to extract number of rows to an internal variable in ST to perform some calculation! I have been trying the following code to extract rows from DataTable but not successful in transferring to internal variables [ Rec_count,val1,val2]
IS TEHRE A WAY TO GET ROWS?
TYPE Records:
STRUCT
Index1:INT;
val1:INT;
val2:INT;
END_STRUCT;
END_TYPE
PROGRAM SQL_EXTRACT
VAR
pump1data :Records;
END_VAR;
VAR
Rec_count :INT;
val1 :INT;
val2 :INT;
END_VAR;
VAR
Test1 AT %S(Select Index1,val1,val2 FROM TEST1_TABLE WHERE Index1 = 2):RESULTSET OF RECORDS;
END_VAR;
IF Test1.Valid = TRUE THEN
Rec_count := pump1data.Index1;
val1 := pump1data.val1;
val2 := pump1data.val2;
END_IF;
END_PROGRAM
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-26 02:10 PM
Reply From User: geoffpatton, posted: 2019-10-08 20:41:59
I think it is Test1.Size is the number of rows
Reply From User: hemanth, posted: 2019-10-10 03:54:32
Thanks..
following link provides more info...
https://www.citect.schneider-electric.com/scada/clearscada/help/2017/Content/LogicGuide/UsinganSTPro...
sbeadle
Kirk sbeadle Kirk
Kirk
Thanks..
