[Imported] Mimic Script Server.Query don't work
  • Remote Operations
  • [Imported] Mimic Script Server.Query don't work
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 02:21 PM . Last Modified: ‎2023-05-03 12:31 AM
User: florian, originally posted: 2018-10-25 20:20:39 Id:303
**_dareksm:_**
**_I cannot receive data when I use function Server.Query from mimic script (from any table)._**
**_I always get the error:_**
_PrepareQuery failed : Unknown Error 0x80072f19_
**_The same query runs in datagrid table works fine._**
**_This is my sample script:_**
Public Sub GetData()_
Dim DGRS _
Set DGRS = Server.Query("SELECT * FROM CDBPoint")_
If NOT(DGRS.Error) Then_
Msgbox OK, vbOK, "NO ERROR"_
Else_
Msgbox DGRS.ErrorMessage, vbCritical + vbOKOnly, "Error in SQL Command"_
End If_
End Sub_
AWoodland:
Have a look at http://resourcecentre.controlmicrosystems.com/display/CS/Diagnosing+Scripting+Connection+Errors, it should help you identify the possible causes.
The mostly likely cause is that the ClearSCADA WebX port is in use by something else, IIS for example, and so ViewX scripting can't connect to get data.
  • SCADA
Replies 0
