[Imported] Logic Audit: Record users who launched logic
Send InviteCancel
Posted: 2019-11-0512:33 PM. Last Modified: 2023-05-0312:37 AM
>>Message imported from previous forum - Category:Scripts and Tips<< User: mchartrand, originally posted: 2018-10-23 17:20:42 Id:177 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum.
_________________
**_NIWTelemetry: Hi everyone. I have created an application which permits key users to disable point alarms within a given geographic area for a 3 hour period. All works well. Now my problem. I need a way to record for auditing purposes the user and date time when the logic was executed.The logic is executed from a button on a mimic. Looking for ideas. Thanks. Tony_**
_________________
bevanweiss: don't believe there's an amazingly nice way to do this. You might want to make the username another parameter to the logic.
Then you could have the logic write this into a data table along with the point ID and expiry time etc.. __________
**_NIWTelemetry: Thank you for your reply. Indeed this is what I was thinking._**
