[Imported] Invalid Internal Alarm State!
Showing results forΒ
Did you mean:Β
  • Remote Operations
  • [Imported] Invalid Internal Alarm State!
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxureβ„’ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: β€Ž2019-11-06 09:38 AM . Last Modified: β€Ž2023-05-03 12:28 AM
1227
User: yasinnajib, originally posted: 2019-01-28 05:37:35 Id:354
Dear Friends,
Can you please tell me how I can interpret this alarm?
![]((see attachments below) a3/7t5lvo4qmjgu.jpg "")
Every time I acknowledge this alarm, the server crashes. I am unable to delete the template instance as this crashes the server.
Thanks in advance for your comments!
Attached file: (editor/a3/7t5lvo4qmjgu.jpg), ClearSCADA invalid state alarm.jpg File size: 174398
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: β€Ž2019-11-06 09:39 AM
Reply From User: Omar_Gadallah, posted: 2019-01-28 11:07:52
Have a look In: Server Configuration Database Configuration Severities
You have to define the same serverities used in your points as configured on your database projects.
Reply From User: yasinnajib, posted: 2019-01-28 12:01:28
[at]Omar_Gadallah Thank you for your kind reply. The severities match. 😞
Reply From User: BevanWeiss, posted: 2019-01-28 20:28:31
[at]yasinnajib I'd recommend that you raise this with your local Technical Support contact. They would be in the best position to assist with this.
I'm intrigued however, I'm not sure I've seen this 'State Alarm' before. And the Alarm State is Normal, so there doesn't appear to be an alarm on this object.
Can you please show an image of the alarm from the alarm banner?
Have you looked through the ClearSCADA log file to identify anything else about the exception?
Reply From User: yasinnajib, posted: 2019-01-29 02:07:54
[at]BevanWeiss Thank you for your support.
I've gone through the log file and sent it to Schneider as well.
They suggested the same fixes you and Omar have suggested. In the end, they agreed to remotely connect and check the error by themselves.
I'll post the prognosis, whatever it may be.
Reply From User: adamwoodland, posted: 2019-01-29 03:21:54
Can you post a screenshot of your Server Configuration - Database Configuration - Point State Alarms. Curious if anything is enabled there, I doubt it but may aswell check.
1,811,964,416 doesn't seem 'interesting'. If its some overflow then its a big one, hex is 0x6C006200 which just seems oddly convenient. The string 'lb' perhaps.
Your screenshot shows what I assume are metadata fields you've added ("String that represents the formatted value and quality"). How is that field manipulated? Assuming logic could it be writing to a property it shouldn't be able to (would be a ClearSCADA bug if so).
Maybe also, from the database bar right click and Locate in OPC Explorer, that should highlight the object in the OPC Explorer. Right click and choose Display Values and see if there is anything odd in there (or include a screenshot here). That field could be manipulates by the OPC-DA source (I'm not sure off the top of my head if that is one of the fields that is) and perhaps its dodgy data from the OPC source?
sbeadle
Kirk sbeadle Kirk
Kirk
Β
