Posted: 2019-11-06 11:12 PM . Last Modified: 2023-05-03 12:24 AM
User: alexs, originally posted: 2019-05-31 04:42:16 Id:441
After updating ClearSCADA 2015 to ClearSCADA 2017 I faced with problem in IEC60870-104 driver. The driver spontaneously fails with error "80004005 - Unspecified error". Has anyone faced this problem?
Logging started at 30-MAY-2019 01:30:41.188 (UTC)
File : C:\\ProgramData\\Schneider Electric\\ClearSCADA\\Logs\\Drivers\\DriverIEC60870_001.log
System : Microsoft Windows Server 2012 R2 Standard Edition, 64-bit (6.3.9600)
CPU : 1 x Intel Unknown Family 6, Model 79, Stepping 1
Intel(R) Xeon(R) CPU E5-2620 v4 [at] 2.10GHz
ClearSCADA Core : Build 6.78.7021.1 (Release)
Local time zone : UTC+05:00 (no DST)
Computer : SVD-AD01-SCDA01
Driver : IEC60870
Started : 30-MAY-2019 01:30:41.188
Uptime : 0 00:00:00.000
Logging options:
APP : Application
ERR : Errors
OBJ : Database Objects
CHN : Channels
SET : Outstation Sets
OS : Outstations
PNT : Points
SCN : Scanners
REQ : Requests (Actions)
DAT : Point Updates (Data)
APL : IEC60870 Application Layer
Threads:
5444 : Main
Registry settings:
HKEY_LOCAL_MACHINE\\Drivers\\ErrorMsgBox = False
HKEY_LOCAL_MACHINE\\Drivers\\HeartbeatEavesdrop = False
HKEY_LOCAL_MACHINE\\Drivers\\ServerPollInterval = 5000
HKEY_LOCAL_MACHINE\\Drivers\\AsyncPointRequests = True
HKEY_LOCAL_MACHINE\\Drivers\\SecondaryDataMaxPointUpdates = 250
HKEY_LOCAL_MACHINE\\Drivers\\MaxPendingAsyncPointRequests = 300
HKEY_LOCAL_MACHINE\\Drivers\\ValueMapScanningInterval = 1000
HKEY_LOCAL_MACHINE\\Drivers\\SelectBestChannel = False
HKEY_LOCAL_MACHINE\\Drivers\\BreakDuration = 100
HKEY_LOCAL_MACHINE\\Drivers\\PostHangupDelay = 0
HKEY_LOCAL_MACHINE\\Drivers\\TimeJumpLimit = 50
HKEY_LOCAL_MACHINE\\Drivers\\RequestTimeout = 600
HKEY_LOCAL_MACHINE\\Drivers\\RequestTimeoutExtn = 300
HKEY_LOCAL_MACHINE\\Drivers\\ScannerCommandTimeout = 30
HKEY_LOCAL_MACHINE\\Drivers\\ScannerRequestTimeout = 180
HKEY_LOCAL_MACHINE\\Drivers\\EavesdropPSTNTimeout = 30
HKEY_LOCAL_MACHINE\\Drivers\\RxFailureLimit = 10
HKEY_LOCAL_MACHINE\\Drivers\\TxFailureLimit = 10
HKEY_LOCAL_MACHINE\\Drivers\\RetryAssignInterval = 30
HKEY_LOCAL_MACHINE\\Drivers\\RxTimeoutLimit = 20
HKEY_LOCAL_MACHINE\\Drivers\\TxTimeoutLimit = 20
HKEY_LOCAL_MACHINE\\Drivers\\GracefulSocketCloseTimeout = 1000
HKEY_LOCAL_MACHINE\\Drivers\\AllowInboundConFromAllOS = False
HKEY_LOCAL_MACHINE\\Drivers\\DirectOnDemandRetryPeriod = 120
HKEY_LOCAL_MACHINE\\Drivers\\ComtrolFreeportDelay = 250
HKEY_LOCAL_MACHINE\\Drivers\\MaxBatchWriteSize = 1000
HKEY_LOCAL_MACHINE\\Drivers\\ListenPortRangeStart = 0
HKEY_LOCAL_MACHINE\\Drivers\\ListenPortRangeEnd = 0
HKEY_LOCAL_MACHINE\\DriverIEC60870\\LogEnableTelnet = False
30-MAY-2019 01:30:41.204 [Data Cache] Started new thread (ID=9152)
HKEY_LOCAL_MACHINE\\DriverIEC60870\\24BitTimeStampMaximumForwardOffset = 1
30-MAY-2019 01:30:41.204 [Main] Database classes (37)...
Name |Type
CProfile |Resource
CProfileFloat |Resource
CProfileULong |Resource
CProfileLong |Resource
CAdvBITValueMap |Resource
CAdvBYTEValueMap |Resource
CAdvWORDValueMap |Resource
CAdvDINTValueMap |Resource
CAdvUDINTValueMap |Resource
CAdvREALValueMap |Resource
CAdvDOUBLEValueMap |Resource
CAdvStringValueMap |Resource
CDynacardStore |Resource
CAdvOutstation |Modem
CIEC60870ChannelDirect |Channel
CIEC60870ChannelPSTN |Channel
CIEC60870LinkDirect |Outstation
CIEC60870LinkShared |Outstation
CIEC60870OSLinkLayer |Broadcast Outstation
CIEC60870OSDirect |Outstation
CIEC60870ASDU |Outstation
CIEC60870OSPSTN |Outstation
CIEC60870OSShared |Outstation
CIEC60870LinkSlDirect |Outstation
CIEC60870SlOSLink |Broadcast Outstation
CIEC60870SlOSDirect |Slave Outstation
CIEC60870SlASDU |Outstation
CIEC60870AnalogIn |Point
CIEC60870AnalogOut |Point
CIEC60870DigitalIn |Point
CIEC60870DigitalOut |Point
CIEC60870SetDirect |Set
CIEC60870SetSwitched |Set
CIEC60870SetPSTN |Set
CIEC60870SetShared |Set
CIEC60870SlChanDirect |Slave Channel
CIEC60870SlSetDirect |Slave Set
30-MAY-2019 01:30:41.204 [Scan Value Map] Started new thread (ID=9088)
30-MAY-2019 01:30:41.204 [Main] Error at line 408, file Class.cpp
Advise driver failed
30-MAY-2019 01:30:41.204 [Data Cache] Thread terminated (ID=9152)
30-MAY-2019 01:30:41.204 [Scan Value Map] Thread terminated (ID=9088)
30-MAY-2019 01:30:41.204 [Main] Driver stopped after 0 00:00:00.016
Posted: 2019-11-06 11:13 PM
Reply From User: JesseChamberlain, posted: 2019-06-03 03:31:58
Any reason you've upgraded to CS2017 instead of CS2017R3? I'd suggest upgrading to the latest Update of CS2017 if not the latest Update of CS2017R3 as a first step.
I'd also recommend restarting the server, and re-saving the value maps and slave devices.
Essentially the advise link between the driver and DBServer has failed, apparently when starting to scan a value map. Please get in touch with local CS Support and give them driver, DB and DBSnapshot logs as a starting point. We will probably need to enable additional logging classes.
Reply From User: andrewscott, posted: 2019-06-03 09:07:35
This error is not related to value maps.
To find out why the advise has failed would need the matching DB log showing the **AdviseDriver()** request. The **DBDRQ** logging option needs to be enabled. However, I would suspect that the issue is related to the IEC 60870 driver being invalid (e.g. not licensed), check the "General \\ Modules" page in the server status tool.
