[Imported] How to use internal variables in script?
Send InviteCancel
Posted: 2019-11-0512:30 PM. Last Modified: 2023-05-0312:37 AM
>>Message imported from previous forum - Category:Scripts and Tips<< User: mchartrand, originally posted: 2018-10-23 17:08:00 Id:174 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum.
_________________
**_jiramancio: Say I have an internal long variable named "GenChoice", and I want to incorporate it in my script. Do I have to use a code to call it in my script? And if so, what code is it. I want to use "GenChoice" to store a value: GenChoice = InputBox("Enter number") And once a number is entered, I would display the value of the variable in the mimic._**
_______
geoffpatton: I have done this using a Form to set a variable in the script and then set the Internal Variable to the script variable.
**_jiramancio: Does this apply to all types of variables? I tried to use this in my code but it didn't work. It says "the passed data type cannot be accepted for this item"._**
________________________
geoffpatton: For variables yes it should other than a constant variable, because it is a constant.
You probably need to make it a String or an Integer to be right type. CStr(value) CInt(Value)
_______________
bevanweiss: What's the full use-case here?
You should keep in mind that ClearSCADA is a multi-user environment, so storing a value into the database (against an internal long) will be shared across all users, and not specific to a single user.
If you want this to be specific to a single user, and not shared across all users, then you might want to consider using the Registry script / animation methods.
