[Imported] Faceplate Editing
  • Remote Operations
  • [Imported] Faceplate Editing
sbeadle
Kirk sbeadle Kirk
318
AndrewScott
Admiral AndrewScott
109
BevanWeiss
Spock BevanWeiss
96
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:57 AM . Last Modified: ‎2023-05-03 12:29 AM
1154
>>Message imported from previous forum - Category:General Items<<
User: KylePaynter123, originally posted: 2018-11-30 19:04:12 Id:329
Hi guys
I'm New to this and I have been trying to figure out how to edit the name of a currently created and work face plate for a Level Indicator it has the wrong name and I'm trying to adjust it so when the Mimic is clicked the correct name to the face plate comes up
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:58 AM
Reply From User: dmercer, posted: 2018-12-04 22:06:57
If you rename an object in the database, the references to that object should be updated automatically, unless they have been hard coded as a string in single quotes in an animation. You'll just need to be logged in with sufficient privileges. Or is this name that you're referring to based off something else?
Reply From User: KylePaynter123, posted: 2018-12-07 12:33:01
Hey
I made some progress I edited a new face plate and and did the necessary pick action.
However I just need to allow the face plate to show the alarm limits for the level indicator when clicked.
for now the only thing I got to work was the name of the faceplate
if you have any suggestions let me know
Reply From User: KylePaynter123, posted: 2018-12-12 16:53:34
However [at]dmercer I will use our test system and see how that works with ref to changing the name on the Database thanks !
sbeadle
Kirk sbeadle Kirk
Kirk
Hey
