[Imported] Export and import data from a file XML (EXCEL)
  • Remote Operations
  • [Imported] Export and import data from a file XML (EXCEL)
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 01:59 PM . Last Modified: ‎2023-05-03 12:33 AM
>>Message imported from previous forum - Category:Scripts and Tips<<
User: mchartrand, originally posted: 2018-10-25 19:18:49 Id:277
_______
**_PavelUKR:
Hi, all! Please, prompt the easiest way to export and import data from a file XML (EXCEL). Thanks._**
______________
bevanweiss:
What kind of data are you talking about?
I assume you mean historical data, in which case writing some VBA using the DBClient.DLL is the way most people go about it.
You find your point, and then you can either LoadDataValue(s), or you can set the PresetTimestamp / PresetQuality and then the CurrentValue field.
Exporting to Excel format is best done using the Crystal Reports engine.
It is also possible to use an SQL Export, however it doesn't allow as much accusation.
____________________________
**_PavelUKR:
Thank You for response. I try use ODBC query for my task. But I don't know, how write SQL query. Maybe is it wrong way?_**
______________________________
**_PavelUKR:
A solution is found!_**
  • SCADA
Replies 0
