[Imported] DNP3 point noisy - Not honouring significant change setting
  • Remote Operations
  • [Imported] DNP3 point noisy - Not honouring significant change setting
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 03:21 AM . Last Modified: ‎2023-05-03 12:29 AM
1019
User: nminchin, originally posted: 2019-01-08 00:24:26 Id:345
I have a DNP3 point, an analogue point measuring motor current, that is recording over 200,000 records a week into the history, and is not honouring its significant change setting.
Point significant change is set to absolute 0.5, however as you can see from the attached image, there are sequential records in the history with less than 0.5 between them.
Historic compression isn't configured (apply to No Data).
Am I missing something?
![]((see attachments below) qr/ytsx351kahbp.png "")
![]((see attachments below) ys/bd5ju32cobmj.png "")
Cheers,
Nick
Attached file: (editor/ys/bd5ju32cobmj.png), image.png File size: 23675
Attached file: (editor/qr/ytsx351kahbp.png), sig change.PNG File size: 2844
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 03:22 AM
Reply From User: JesseChamberlain, posted: 2019-01-08 01:56:37
Deadband only applies to 'Current Data'. If the RTU sends an event for Value Change, it bypasses the deadband.
You need to modify event settings on the RTU.
Doco ref _Core Reference Core Point Configuration Defining Analog Point Details Define the Criteria for a Significant Change in Value_.
Reply From User: nminchin, posted: 2019-01-08 05:04:55
Thanks Jesse, I read the help before but must have missed where it talked about only applying to the current data. The property box heading is somewhat misleading... I'll make the change in the RTU 🙂
sbeadle
Kirk sbeadle Kirk
Kirk
