Posted: 2019-11-26 01:52 PM . Last Modified: 2023-05-03 12:21 AM
User: KylePaynter123, originally posted: 2019-09-18 16:29:58 Id:518
Good Day guys,
I'm trying to create a button to filter a SQL query for example
I have a query that shows all alarms for Loss of power, but I want to add a filter button to search description of the location.
thanks guys
Posted: 2019-11-26 01:53 PM
Reply From User: BevanWeiss, posted: 2019-09-18 21:45:32
There are two main ways to do this:
1) Have the SQL query as an animation
2) Use scripting to change the SQL query
My recommendation is option 1.
You would likely want to look into the REGISTRY() animation method, and then you can use Pick Actions on the buttons to set appropriate entries in the Registry which then influence the SQL query... simples... 😉
Reply From User: du5tin, posted: 2019-09-27 14:00:45
+1 for Bevan's note. We use option 1 all the time. It is robust and fast. Option 2 is prone to breakage on object renames, depending on how you put your script together.
