Posted: 2024-06-12 02:44 PM
Hi
I want to limit my IIF to a range od setpoints to change color of an object. For example :
IIF 0 < x < 0.3 ---> Green
IIF 0.3 < x < 0.5 ---> ORANGE
IIF 0.5 < x < 1 ---- RED
I tried the following line but it is not working:
IIF("..Control Points.NTU1_Control_Points.NTU1.CurrentValue" > 0 AND "..Control Points.NTU1_Control_Points.NTU1.CurrentValue" < 0.5,RGB( 0, 255, 0 ),RGB( 255, 0, 0 ))
I couldn't not find any clues how to do that in GeoSCADA help. Any Idea how I can write these condition for an object?
Posted: 2024-06-13 03:14 AM
You need to nest the IIF statements, something like:
IIF("x" < 0, Black, IIF("x" < 0.3, Green, IIF("x" < 0.5, Orange, IIF("x" < 1, Red, Black))))
which uses black for values outside of the range zero to one.
IIF("..Control Points.NTU1_Control_Points.NTU1.CurrentValue" < 0, RGB( 0, 0, 0 ), IIF("..Control Points.NTU1_Control_Points.NTU1.CurrentValue" < 0.3, RGB( 0, 255, 0 ), IIF("..Control Points.NTU1_Control_Points.NTU1.CurrentValue" < 0.5, RGB( 255, 142, 85 ), IIF("..Control Points.NTU1_Control_Points.NTU1.CurrentValue" < 1, RGB( 255, 0, 0 ), RGB( 0, 0, 0 )))))
Posted: 2024-06-16 06:56 PM
Thanks Andrew
Working with no issue. I was thinking I should use something like &&, AND or similar like C, VB and so on.
Regards
