IEC61850 Configuration in Geo SCADA
Send InviteCancel
Posted: 2023-10-1002:12 AM
I have configured an IED into Geo SCADA via the SCL File. The IED displays 'Healthy' quality, the Logical Devices display 'Disconnected' state although 'Good' quality, the Logical Nodes display 'Unknown' state although 'Good' quality, the points display 'Good' quality.
The problem I have is the points do not display any realtime / live data.
I have used IED Scout to confirm realtime / live data is available.
If I look at Authentication on IED Scout there is 'None'.
Has anyone configure Geo SCADA to an IED via IEC61850 successfully?
