How to monitor an Easy logic pm2200 remote
  • Remote Operations
  • How to monitor an Easy logic pm2200 remote
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
todon
Crewman todon
Crewman
Posted: ‎2025-01-24 10:45 PM
839
We currently have an EasyLogic PM2200 installed in our electrical system. I am interested in exploring remote monitoring options for this device. Specifically, I would like to know if it's possible to remotely view and analyze the data it collects.
Thank you for your time and assistance.
  • IAN (Instrument Area Network)
  • IoT
  • Logic
  • Radio
  • SCADA
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-01-28 12:27 AM
811
Looks like if you have the right variant it supports Modbus over RS485. Any SCADA including Geo SCADA can read it. You will need a USB or Serial to RS485 adapter.
Check:
https://iportal2.schneider-electric.com/Contents/docs/EasyLogic%20PM2200%20series%20User%20Manual.pd...
sbeadle
Kirk sbeadle Kirk
Kirk
812
Check:
todon
Crewman todon
Crewman
Posted: ‎2025-02-04 06:49 AM
In response to sbeadle
Hi, Thank you for the reply. I found another way to connect it : Easy logic pm2200 (with RS-485 port) - RS-485 cable - Moxa NPort 5110 (receives RS-485 cable and converts it to Ethernet) - RJ45 cable - Teltonika RUT240 router or similar (If the installation is in an area without wired network access, a 4G LTE router is required) + SMA antenna (connected to the router's MAIN LTE port to improve signal) - Grafana Dashbord
