How to filter by Timestamp in CearSCADA ODBC?
  • Remote Operations
  • How to filter by Timestamp in CearSCADA ODBC?
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2020-10-05 09:08 AM . Last Modified: ‎2023-05-03 12:09 AM
2379
SELECT ID,VALUEAsReal, RecordTime, RecordId
FROM  CDBHISTORIC
WHERE RecordTime > {ts '2019-10-17 13:00:00'} AND ID = 40776 OR ID = 26114
I am trying to filter the results from CDBHISTORIC like so, I have also tried BETWEEN the chosen date and current timestamp but everything is giving me the same error. It returns all values from those ID's normally with out timestamp filtering.
Error in SQL statement: ODBC-call returned [-1] : [HY000][0][Control Microsystems][ClearSCADA database driver]Historic query not constrained by object, or could not be optimised efficiently
 What am I doing wrong?
  • SCADA
  • ClearSCADA ODBC
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
  • SCADA web application
  • Telemetry and SCADA
Posted: ‎2020-10-05 09:18 AM . Last Modified: ‎2020-10-05 09:20 AM
2376
Never god **bleep** mind, I literally found the solution two seconds after I posted this. Here is the correct SQL
FROM  CDBHISTORIC
WHERE RecordTime > {ts '2019-10-17 13:00:00'} AND (ID = 40776 OR ID = 26114)
 You have to put the parenthesis () for the other filters: (ID = 40776 OR ID = 26114)
*sigh* why is my life like this.
Some documentation about this can be found here: http://34.236.135.167/Help/Default.htm#SQLGuide/BuildtheSubClauseList.htm%3FTocPath%3DCore%2520Refer...
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
2377
FROM  CDBHISTORIC
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: ‎2020-10-06 10:04 PM
In response to Anonymous user
AND takes precedence over OR, so your original query was really
Give me all historic where:
* RecordTime > {ts '2019-10-17 13:00:00'} AND ID = 40776
* OR give me all data for ID = 26114
When you added the brackets you made the logical part change
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
