Posted: 2020-02-09 05:14 PM . Last Modified: 2023-05-03 12:17 AM
I wish to have clarification.
We have to connect GeoSCADA to a Web Gateway that will be communicating via SOAPui with XML / Json files.
From what I have read GeoSCADA has no means to de-serialise this format internally?
If this is the case, a Web Server / Client is to built in order to de-serialise the XML files and write values to internal GeoSCADA points via OPC?
(a driver to be created by the DDK).
An additional Web Server / Client cannot be avoided to achieve this path of communications.
Posted: 2020-02-09 05:18 PM
Correct, you will need to develop an intermediate 'application' which is able to act as a client to both your 'Web Gateway', and also to Geo SCADA Expert / ClearSCADA (whether via SOAP / .NET API / Automation Interface / Simple DDK).
Posted: 2020-02-12 02:12 PM
I believe that my answer has addressed the question that you asked. Please mark it as the solution.
