Geo SCADA Web Services
  • Remote Operations
  • Geo SCADA Web Services
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
97
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
DavidSkilbeck
Lt. Commander DavidSkilbeck
Lt. Commander
Posted: ‎2020-01-12 10:17 PM . Last Modified: ‎2023-05-03 12:19 AM
2055
has anyone set up a web service to retrieve information from eDNA to use in Geo SCADA?
  • SCADA
  • eDNA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-01-13 12:23 AM
Does eDNA support Web Service?
The last time I looked at it, eDNA had an ODBC (SQL) type of connector to it, and that was about it.
If so, then you could use the ODBC Driver from Geo SCADA Export to retrieve data from eDNA.
Otherwise if the EcoStruxure Web Service stuff is now available out of eDNA then you could use that (if it's available, then it's probably the best option).  Configuration side in GeoSCADA Expert should be quite straight forward, how to configure this in eDNA is a different story... and you might have to beat it to death with its own shoe.
  • EcostruxureWebService
  • eDNA
  • odbc
BevanWeiss
Spock BevanWeiss
Spock
  • eDNA
  • odbc
