Finding historic data files by largest size
  • Remote Operations
  • Finding historic data files by largest size
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-01-18 04:44 AM
2
1122
Today I was asked where the largest historic files are. I came up with this query which finds and names the top 10 largest:
select top (10) p.fullname, f.RecordCount, f.StartTime,
'History\Historic\HdI' || formatvalue( p.id/256 using '00000') || '\' || formatvalue( p.id using '00000') || '\WK' || formatvalue( f.granule using '000000') || '.HRD' as filename
from cdbpoint p inner join cdbhistoricfile f on (p.id = f.objectid)
order by f.RecordCount desc
Results below.
Reading the historic file table is much more efficient than ploughing through individual historic records. Take care though if your system has an 'Index After' setting because the server will need to enumerate these older files, taking time, cache and CPU to do it.
You can build similar queries for Events, Alarm Summary and Configuration Change records. You could add your queries in reply to this post!
Steve
Row | FullName | RecordCount | StartTime | FILENAME
0 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 10.A 10.Analog | 519030 | 24/04/2023 00:00:00.000 | History\Historic\HdI01639\419777\WK022035.HRD
1 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 07.A 09.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01645\421211\WK022035.HRD
2 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 08.A 01.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01645\421213\WK022035.HRD
3 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 07.A 07.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01645\421214\WK022035.HRD
4 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 07.A 10.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01645\421212\WK022035.HRD
5 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 08.A 04.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01645\421190\WK022035.HRD
6 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 08.A 08.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01639\419778\WK022035.HRD
7 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 09.A 01.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01639\419775\WK022035.HRD
8 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 08.A 05.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01639\419788\WK022035.HRD
9 | Demo Items.Test Bulk Data.d.1000 1.T 10.T 08.A 06.Analog | 519028 | 24/04/2023 00:00:00.000 | History\Historic\HdI01639\419774\WK022035.HRD
  • IoT
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-01-22 05:13 AM
Thanks Adam. Page has been updated.
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
Lt. Commander
Posted: ‎2024-01-21 08:05 PM
https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Finding-large-historic-granules/ba-p/278729 might need an update, especially regarding the index after info
sbeadle
Kirk sbeadle Kirk
Kirk
