Posted: 2025-03-12 09:42 AM
Hi all,
I would like to delete certain historical values inside Geo SCADA with a script, using the .NET API.
It seems to me that the problem is that it does not see the milliseconds of the RecordTime.
I created a calculated variable, every minute increases the value by 10, I also ran it manually to ensure that the timestamp has milliseconds other than 000:
If I run the following lines of code it only works where the timestamp has milliseconds 000:
Dim PointObj = connection.GetObject("New Analog Point")
Dim startTime As DateTime = DateTime.Parse("2025-03-11 17:48:00.000")
PointObj.Aggregates("Historic").InvokeMethod("DeleteValue", {startTime, 3, ""})
Is there something I'm doing wrong?
Thanks!
Posted: 2025-03-27 02:30 AM
Even milliseconds might not be enough. I think you may need to read the actual time from an API call to get raw history and use that to delete the record.
Posted: 2025-03-13 02:54 AM
I suspect you need to use DateTime.ParseExact() rather than DateTime.Parse() to parse a string that contains milliseconds, something like:
DateTime.ParseExact("2025-03-11 17:48:00.000", "yyyy-MM-dd HH:mm:ss.fff", CultureInfo.InvariantCulture);
https://learn.microsoft.com/en-us/dotnet/api/system.datetime.parseexact?view=netframework-4.8
Posted: 2025-03-13 07:39 PM
I thought the DateTime data type didn't support milliseconds? Maybe that was just under VBA and VBScript.
I always used DateTimeOffset as the data type to use for these.
Posted: 2025-03-18 02:24 AM
I tried this but it still doesn't work
