Creating DB object insie Geo SCADA using pythonnet
Select a Country
  • Remote Operations
  • Creating DB object insie Geo SCADA using pythonnet
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
krishnaprasad68
krishnaprasad68
Explorer
Posted: ‎2021-10-17 05:34 AM . Last Modified: ‎2023-05-03 12:01 AM
2
2816
I have a specific need in ClearSCADA where i have to create hundreds of Internal Analog points and add them to Word Value maps. I have been trying to accomplish the task using Clear SCADA automation interface - utilizing pythonnet. Can you guys suggest any methods by which I can accomplish the task.
up till now, I tried using CreateObject method. but it is throwing an exception "TypeError: No method matches given arguments for CreateObject"
I am attaching the code fragment where create Object method is called and the exception that is thrown.
Can you guys please take a look at the code to suggest any corrections that are to be made?
  • automation
  • ClearSCADA
  • Create Object
  • Geo SCADA
AndrewScott
AndrewScott
Leader
Posted: ‎2021-10-18 04:07 AM . Last Modified: ‎2021-10-18 04:16 AM
1
2796
If you look at the documentation for the DBObject.CreateObject method you'll see it only has two arguments (not three), the class name and the object name.
DocumentationDocumentation
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
AndrewScott
Leader
1
2797
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
krishnaprasad68
krishnaprasad68
Explorer
Posted: ‎2021-10-24 03:59 AM
In response to AndrewScott
Thanks @AndrewScott  for pointing out the issue. it worked while using the correct parameters👍
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
