Create point from mimic script
  • Remote Operations
  • Create point from mimic script
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
IvanDeMarco97
Lieutenant JG IvanDeMarco97 Lieutenant JG
Lieutenant JG
Posted: ‎2023-03-20 01:09 AM . Last Modified: ‎2023-05-02 11:46 PM
1391
Hello all,
I would like to create an internal analog point through a script called from a mimic button.
What is the function to use?
Thanks!
Ivan
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
Lt. Commander
Posted: ‎2023-03-20 09:22 PM
You can't directly, need to create a COM object for the Automation interface and use that. There's an example at https://www.se.com/au/en/faqs/FA280488/
AdamWoodlandToo
Lt. Commander
du5tin
Lt. Commander du5tin
Lt. Commander
Posted: ‎2023-03-21 03:56 PM
Depending on the point type and the user permissions we have successfully created objects using an INSERT SQL query via vbscript.
The user executing the command probably needs to have the "Edit SQL" check box enabled in their user.
Something like:
' other script stuff that comes before the creation
' this example for creating a template instance
sql = "INSERT INTO CTEMPLATEINSTANCE (Name, ParentGroupId) VALUES ('instanceName', templateId)"
Set query = Server.Query(sql)
' Error handling and all that
' Updating point configuration with comm settings and such
