Cleanup Thinfinity Log Files for Virtual ViewX
  • Remote Operations
  • Cleanup Thinfinity Log Files for Virtual ViewX
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
du5tin
Lt. Commander du5tin
Lt. Commander
Posted: ‎2023-03-23 12:15 PM . Last Modified: ‎2023-05-02 11:46 PM
1343
Has anyone had to deal with Thinfinity (part of VVX) logs filling up their hard drive when they are enabled?
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
du5tin
Lt. Commander
Posted: ‎2023-03-23 12:17 PM
Here is a powershell scrip that can be used to clean up Thinfinity log files older than a week so that the logs don't fill the hard drive. Trigger it with Windows Task Scheduler. This script assumes the location of the logs was customized to C:\Geo SCADA\Logs.
# Clean-up script for removing logs older than '$cutoff' days from a folder
# This script is recursive and will get files inside subfolders as well
# Built by: Dustin Symes
# Date: February 5, 2023
# With assistance from ChatGPT
$folder = "C:\Geo SCADA\Logs"
$cutoff = (Get-Date).AddDays(-3)
# Use this line to print the file names to console
#Get-ChildItem $folder -Recurse | Where-Object { $_.LastWriteTime -lt $cutoff -and $_.PSIsContainer -eq $False } | Select-Object -ExpandProperty Name
# Use this line to delete the files
Get-ChildItem $folder -Recurse | Where-Object { $_.LastWriteTime -lt $cutoff -and $_.PSIsContainer -eq $False } | Remove-Item
du5tin
Lt. Commander
