Cannot Change Marker Limit using .NET API and ViewX Automation
Select a Country
  • Remote Operations
  • Cannot Change Marker Limit using .NET API and ViewX Automation
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
du5tin
du5tin
Mentor
Posted: ‎2020-09-14 09:05 PM . Last Modified: ‎2023-05-03 12:10 AM
1380
I am working with ViewX automation to program the creation and update of thousands of trend objects. Templates won't work here, the customer has many different internal opinions about which trends look good.
I can seem to edit almost all the properties but I cannot seem to edit the Marker limit or other marker properties.
private void AddTrace(dynamic traces, string relativePath, string label,
	TraceDataMode mode, TraceColors color, string yaxis, DrwDashStyle style = DrwDashStyle.DashSolid)
	// added for CS 2017 R2 August
	System.Threading.Thread.Sleep(1000);
	dynamic newTrace = traces.Add(mode, _systemName, relativePath);
	newTrace.Label = label;
	newTrace.TraceStyle = TraceStyle.TraceLine;
	newTrace.Interval = "5M";
	newTrace.LineColour = (int)color;
	newTrace.LineStyle = style;
	newTrace.LineWidth = 1.0;
        newTrace.MarkerLimit = "0";   // This line and the next two fail
        newTrace.MarkerSize = 2;      // What is the correct field name?
        newTrace.MarkerStyle = MarkerStyle.Diamond;  // Fails too (this enums to zero)
	newTrace.ShowMarkers = 0;
	newTrace.ShowAnnotations = 0;
	newTrace.ShowAlarmLimits = 0;
	newTrace.YAxis = yaxis;
  • SCADA
  • ViewX
du5tin
du5tin
Mentor
Posted: ‎2020-09-15 12:19 AM
So I ended up figuring out something and getting this working. Updated code looks like:
	newTrace.MarkerLimit = (int)1; // I think the API won't let values less than 1 go by
	// Following two lines were not required for this config, commented out
	// newTrace.MarkerSize = 2;
	// newTrace.MarkerStyle = MarkerStyle.Diamond;
du5tin
du5tin
Mentor
