Add Date&Time Information
  • Remote Operations
  • Add Date&Time Information
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
abdullah123456789
Lt. Commander abdullah123456789
Lt. Commander
Posted: ‎2023-06-02 07:29 AM
1899
How can I show the current date and time information on the Mimic screen in Geo Scada? I created a Time Array for this, but it only shows the time when I created it, there is no change. Is it possible to show the time of the system?
  • SCADA
  • Virtual ViewX
  • WebX
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2023-06-02 08:13 AM
Not quite the same, buy you can display a clock in the ViewX status bar, see "Add a Clock to the Status Bar on a ViewX client" section in Miscellaneous Options for ViewX Clients in the help.
To have a clock on a mimic you need to create a Variable of type "Time" and a logic program that periodically  (e.g. every second) writes the current time to the variable, for example a Function Block Diagram using the NOW function. You can then animate the value of the Variable on a mimic. See NOW Function and Types of Variable.
Andrew Scott, R&D Principal Technologist, AVEVA
AndrewScott
Admiral AndrewScott
Admiral
