Time (Local) and Time (UTC) Not Synchronize Even After Enable NTP Server
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Time (Local) and Time (UTC) Not Synchronize Even After Enable NTP Server
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
aliffdani
Crewman aliffdani
Crewman
Posted: ‎2025-02-11 11:38 PM
1910
Hi, I need help. In Ecostruxure Automation Expert, I already enabled the NTP server and set the ip address same as ip PC used (10.10.181.30), but it still not synchronize with Modicon M251 dPAC. Is there any steps that I mislook? Can check the picture attached as reference.
mohamedriswan
Ensign
Posted: ‎2025-02-13 08:47 PM
In response to aliffdani
1832
Can you try adding the time from the physical topology by selecting the Hardware? and check if it taking or not.
Replies 5
mohamedriswan
Ensign
Posted: ‎2025-02-12 08:35 PM
1873
Hi Aliffdani
Did you deployed the device configuration?
aliffdani
Crewman aliffdani
Crewman
Posted: ‎2025-02-12 10:07 PM
In response to mohamedriswan
1857
Yes, already deployed and already reboot
mohamedriswan
Ensign
1833
aliffdani
Crewman aliffdani
Crewman
Posted: ‎2025-02-15 11:02 PM
How to do that? i didnt understand
aliffdani
Crewman aliffdani
Crewman
Posted: ‎2025-02-16 06:14 PM
Okay, already solved the issue, thank you.
