Script Error Display
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Script Error Display
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
treesa21
Crewman treesa21
Crewman
Posted: ‎2024-08-07 05:12 PM
36520
We have Schneider Automation Server with Andover Continumm B3810 series. In the webstation the web graphics is displaying an error message pop up "Script error in DocumentLoadEvent(Bind) ReferenceError:MutationEvent is not defined do you want to continue script." After we click "Ok" it still keeps popping up. Also the graphics is not loading value. For example, OAT reading XXX.
Could you please assist in resolving this display error in the PC.
  • Hardware platforms
  • Portability-Interoperability-Configurability
sesa373560
Crewman sesa373560 Crewman
Crewman
Posted: ‎2024-08-12 04:19 PM
8
36429
Hi Team,
We had the same issue at a site here. The issue is something to do with Mutation Events inside of chrome and Microsoft Edge. We have found a solution in the browsers with "flags"
  • Open Chrome or Edge
  • Type in the search bar 'chrome://flags or Edge://flags'
  • Search flags for 'Mutation'
  • In the default drop down box select enable and relaunch the page
When the page reloads it should work again.
Link below is where I found the fix
https://support.ixon.cloud/hc/en-us/articles/15187062105756-Script-error-MutationEvent-is-not-define...
Replies 32
dsmith
Lt. Commander dsmith
Lt. Commander
Posted: ‎2024-08-12 11:33 AM
We are getting the same issue.
sesa373560
Crewman
8
36430
Hi Team,
CraigEl
Administrator CraigEl Administrator
Posted: ‎2024-08-12 05:32 PM
1
36426
@treesa21 this is a known issue in EBO. "MutationEvent is not defined" Javascript errors are displayed after Chromium based browsers (Chrome or Microsoft Edge) are updated to version 127.
As referenced in Mutation events will be removed from Chrome  |  Blog  |  Chrome for Developers, Google has deprecated these Mutation events and replaced them with a different function. EBO hotfixes are available for all currently supported EBO versions, your local EBO System Integrator or SE branch will have access to the hotfixes.
Regis_Martin
Ensign Regis_Martin Ensign
Ensign
Posted: ‎2024-10-24 11:43 PM
In response to sesa373560
Thank you very much for this really helpful solution. I met the same issue with the Web access to EBO.
amiteshgh
Crewman amiteshgh Crewman
Crewman
Posted: ‎2024-11-14 12:24 AM
Thanks for your valuable information
cabria
cabria
Cadet
Posted: ‎2024-12-22 08:15 PM
In response to CraigEl
Hi @CraigEl,
We have Enterprise Server 3.3.1.2301 installed on our building.
We have problems with our local EBO System Integrator and does not want to apply hotfix.
Can you provide us the link to the hotfix so I can apply it?
Thanks in advance.
PierreRoberts
Lieutenant | EcoXpert Master PierreRoberts Lieutenant | EcoXpert Master
Posted: ‎2025-01-06 05:17 AM
The same issue on this site where we are running version 6.
Resolved it with the helpful solution of above on Chrome and Edge, will run the Hotfix on the Server as well.
Kind regards,
Sufyan_Alkhateeb
Ensign Sufyan_Alkhateeb Ensign
Ensign
Posted: ‎2025-01-21 11:47 AM
Same issue I faced with latest EBO version 6.0.4.90
I know this issue was solved with hotfix, but it is very strange to pop-up again with latest release.
Only FireFox working fine, other browser (MS Edge & Chrome) shows same error "DocumentLoadEvent"
edps
edps
Cadet
Posted: ‎2025-04-07 05:14 AM
With the latest browser updates the hotfix is ​​gone and it doesn't work anymore. Are there any other solutions?
k0
Crewman k0
Crewman
Posted: ‎2025-04-07 11:17 PM
Hi
We’ve encountered a recurring issue with our EBO solution after the latest Chromium update
When trying to load documents, we’re met with the following script error
Script error in DocumentLoadEvent (Bind_Value)
Do you want to continue running this script?
It appears that MutationEvent is no longer supported in the latest Chromium version, which breaks part of the functionality in EBO.
We’re currently looking for a solution or workaround.
If anyone has insights, has resolved this, or knows how to adjust the system or browser settings to avoid the issue, we would greatly appreciate your input.
Possible directions we’re considering:
  • Switching temporarily to another browser
  • Adjusting EBO configurations or scripts to avoid deprecated features
  • Any browser-specific settings or flags that might help?
Thanks in advance for any help or suggestions!
josh.shields
Crewman josh.shields
Crewman
Posted: ‎2025-04-08 08:01 AM
4
23845
There is a Chrome/Edge Extension that will resolve this for the time being.
Mutation Events Polyfill - Chrome Web Store
kimiti
kimiti
Cadet
Posted: ‎2025-04-09 01:40 AM
I have just found out with the latest chrome version, the mutation events are not available. Is there any other work around to this?
Ahtisham
Crewman Ahtisham
Crewman
Posted: ‎2025-04-09 03:46 AM
This solution is not working now.
Ahtisham
Crewman Ahtisham
Crewman
Posted: ‎2025-04-09 03:50 AM
After latest updates in Chrome and Microsoft Edge, enabling of Mutation Events is no more working and we are getting script error.
Muriel
Lieutenant | EcoXpert Master Muriel Lieutenant | EcoXpert Master
Posted: ‎2025-04-09 05:39 AM
In response to josh.shields
This extension worked for me, but i aint sure enough about it's security to apply it in a production service honestly. Anyway, let's wait new updates from Schneider i think that's all we got.
leamthistle
leamthistle Cadet | EcoXpert Master
Posted: ‎2025-04-09 09:31 AM . Last Modified: ‎2025-04-09 09:32 AM
23571
Could you please provide a new fix for this. Chrome and Edge have both updated and they have completely wiped out mutation flag enabling entirely.
Lemus
Lemus Cadet | EcoXpert Master
Posted: ‎2025-04-09 12:43 PM
In response to leamthistle
"I'm having the same issue — I can't find that option in Edge. Any solution?"
k0
Crewman k0
Crewman
Posted: ‎2025-04-09 11:15 PM
I recently started using Firefox, but I’ve noticed it doesn’t always work as expected. There are often graphic glitches when displaying certain values. But the browser works fine in general, and it can be used until the bug is fixed so we can go back to using a Chromium browser.
IO_ING
Crewman IO_ING
Crewman
Posted: ‎2025-04-10 12:12 PM
Unfortunately it is not the solution, Schneider must provide support for browser updates. There are clients who, due to security policies, only operate with EDGE or CHROME.
We are waiting for the Schneider solution.
rvbtyx
rvbtyx
Cadet
Posted: ‎2025-04-10 01:45 PM
Today chromium based browsers are removing the possibility to re-enable mutationevent back.
Schneider was doing something to do not use this anymore?
brunoviniciusps
brunoviniciusps
Cadet
Posted: ‎2025-04-12 08:23 AM
Using the palemoon browser it was possible to solve the problem
TrentonHough
TrentonHough
Cadet
Posted: ‎2025-04-14 05:55 AM
Any update on this? Can we please get a fix to this issue?
AlmasAbuov
Lieutenant JG AlmasAbuov
Lieutenant JG
Posted: ‎2025-04-14 11:29 PM
Let me know how the problem is resolved. I have this situation at many sites.
Emil3
Emil3 Cadet | EcoXpert Master
Posted: ‎2025-04-24 02:38 AM
19906
Hi This link has just resolved my issue on site ,the site is running 3.2 but there are other hotfixes for different versions on there.
https://community.se.com/t5/EBO-Known-Issues-Solutions/quot-MutationEvent-is-not-defined-quot-Javasc...
AlmasAbuov
Lieutenant JG
Posted: ‎2025-04-29 05:48 AM
In response to Emil3
Did you just download and install your version of the workstation? Do I need to delete my current version?
YannRib
YannRib
Cadet
Posted: ‎2025-05-12 11:55 PM
It Works 👍
waltl_akintegra
Crewman waltl_akintegra
Crewman
Posted: ‎2025-06-26 12:53 PM
Firefox has stopped working now also. This fix works for me in Edge. I will try Chrome next.
lmurillo_grupod
Lieutenant JG lmurillo_grupod
Lieutenant JG
Posted: ‎2025-06-28 09:50 PM
This is a good solution.  In the case of Mozilla I found a way to activate Mutation Events typing about:config and then searching "Mutation"
Bojan
Admiral Bojan Admiral
Admiral
Posted: ‎2025-07-10 10:26 AM
It seems that the Chrome or Edge Mutation flags are gone, What would be a work-around?
https://developer.chrome.com/blog/mutation-events-deprecation
iacomozzi
iacomozzi
Cadet
Posted: ‎2025-07-15 03:34 AM
1
9261
Try with "IE Mode" in Edge browser, it works! Or install an older Firefox version with update disabled.
MZU
MZU
Cadet
Posted: ‎2025-10-24 01:12 AM
In response to iacomozzi
Reloading in "IE mode" in the Edge browser works indeed.
FYI : Recently the Edge browser added the possibility to add a button in the Edge toolbar to toggle easily the "IE mode" in the browser (see: Settings > Appearance > Toolbar > Internet Explorer mode (IE mode): toggle on)
Mutation flags are gone in recent Firefox browser, so that workaround seems not to be working anymore.
biCker
biCker
Cadet
Posted: ‎2025-11-26 11:22 AM
An easy fix: I installed Firefox version 72.0.2 on a laptop running windows 7, disabled the automatic update and voila: works like a charme out of the box
