SE.EAEportal library for Automation Expert
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • SE.EAEportal library for Automation Expert
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
mokasha
Crewman mokasha
Crewman
Posted: ‎2022-09-21 02:36 PM . Last Modified: ‎2023-07-28 02:22 AM
4789
I have a project that I received from someone else that seems to be missing this library: SE.EAEportal See attached snapshot.
I get this error when I try to unarchive it. I looked at my library list and i can't find this one.
How can I find this library? I don't seem to find it on SE Exchange.
Thanks!
  • IEC 61499
MrX
Crewman MrX Crewman
Crewman
Posted: ‎2022-10-18 12:33 AM
In response to mokasha
2
4364
Please see the attached screenshot.
Best Regards
Thomas
Replies 8
DivyaJayaraman
Crewman DivyaJayaraman Crewman
Crewman
Posted: ‎2022-09-27 06:55 AM
7
4692
This library is required if you are using Automation Expert Asset Link features to connect with either upstream AVEVA Engineering or downstream AVEVA System platform. During EAE installation, you get option to install these plugins, which also installs this library. If you are not using Asset Link functionality, you can safely remove reference to this library from your solution and re-build the solution.”
Thanks & regards
Divya
DP-JYC
Lieutenant JG DP-JYC
Lieutenant JG
Posted: ‎2022-09-29 11:25 AM
In response to DivyaJayaraman
It would be great to be able to download libraries (and all versions) on exchange directly 👍
Something like:
exchange add SE.EAEportal@^22.0
mokasha
Crewman mokasha
Crewman
Posted: ‎2022-10-10 11:10 AM
4487
Hello Divya,
Thanks for your reply.
I didn't see an option to install these plug-ins during installation.
Is there a way to install them after EAE installation is complete?
Thanks!
anandbpillai
Ensign anandbpillai Ensign
Ensign
Posted: ‎2022-10-12 09:18 PM
4432
Can you check the project library references (right click on the solution name inside the application) and then add SE.EAEPortal from the list in Project library references to your project.
Refer snap.
mokasha
Crewman mokasha
Crewman
Posted: ‎2022-10-17 03:18 PM
In response to anandbpillai
4379
I don't see this library on my Installed Library list. Please see snapshot attached.
MrX
Crewman MrX Crewman
Crewman
2
4365
Best Regards
Thomas
DivyaJayaraman
Crewman
Posted: ‎2022-10-18 06:32 AM
In response to MrX
Hi Thomas
Installing the plugins in your snapshot will install the library as well. Let me know the build version if you are still facing the issue, Then i can verify and provide you guidance.
Thanks & regards
Divya
mokasha
Crewman mokasha
Crewman
Posted: ‎2022-10-18 05:48 PM
In response to MrX
That worked. Thanks for your help!
