Share Your Feedback โ€“ Help Us Improve Search on Community!
Interfacing Factory IO v2.5 with EAE v21.2
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Showing results forย
Did you mean:ย
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Interfacing Factory IO v2.5 with EAE v21.2
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxureโ„ข Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
marc_akoto_AUTEM
Ensign marc_akoto_AUTEM
Ensign
Posted: โ€Ž2022-05-12 11:40 PM . Last Modified: โ€Ž2023-07-28 02:23 AM
7
7890
Hi there,
I'm trying to establish a modbus communication between EAE and Factory IO, for simulation purposes.
Configuration is the following:
- Factory IO as Modbus Server, EAE as Modbus client with MODBUSGENTCPS
- Both applications are opened on the same Windows instance
- I tried to set FactoryIO to use the loopBack interface (127.0.0.1) instead of my default NIC (192.168.0.101).
But still no update of the coil value/timestamp.
I'm wondering which step I missed ? (see attachment : EAE project + Factory IO file)
Does anyone have an example project for interfacing EAE with Factory IO please ?
That would be very helpful.
Thanks in advance,
Marc
Modbus attempt with Factory IO x EAEModbus attempt with Factory IO x EAE
EAE_modbus_factoryIO.rar
  • digital twin
Fabrice_Rabetrano
Crewman Fabrice_Rabetrano Crewman
Crewman
Posted: โ€Ž2022-05-13 02:45 AM
6
7861
Hello Marc,
Here is an example project Interfacing Factory IO v2.5 with EcoStruxure Automation Expert v21.2.
You will find in the attached file:
- FactoryIO Scene
- EcoStruxure Automation Expert program
- ModBus connection file that you can import into the program
It is a simple application with three conveyors.
NB: Do not mind the name of the application which is called "OPCUA_Trial"; the connection is made via ModBusTCP.
I hope this can be helpful to you!
Best regards,
Fabrice RABETRANO.
ModBus_Connection_Conveyors.zip
Replies 7
Fabrice_Rabetrano
Crewman
6
7862
Hello Marc,
- FactoryIO Scene
Best regards,
Fabrice RABETRANO.
marc_akoto_AUTEM
Ensign
Posted: โ€Ž2022-05-13 07:28 AM
In response to Fabrice_Rabetrano
Great resource, thanks a lot !
I was able to open both files
Now, where should I import the .hcf ModBus connection file please ?
I'm quite a newbie into EAE ...
comm settingscomm settings
marc_akoto_AUTEM
Ensign
Posted: โ€Ž2022-05-16 02:25 AM
Eventually, after restarting both applications (EAE+FactoryIO), Modbus communication is now working (hardware configuration was already imported in the project)
Now I'm browsing the logic, and I'm having hard time with a variable called "SoftDPac.RES0.Conv1.Motor.output.cmdActive.destination"
@Fabrice_Rabetranodo you have a clue why this variable holds conveyor1 in STOP ? even when a box is present on the first conveyor (... see picture attached)
conveyor1conveyor1
marc_akoto_AUTEM
Ensign
Posted: โ€Ž2022-05-23 02:59 AM
3
7671
For future reference, here's a memo I summarized for interfacing EcostruxureAutomationExpert with FactoryIO via Modbus.
I ended up creating this simpler application just to validate the modbus server-client communication, before moving to more complex logic. Enjoy !
  • modbus
Laurent_F
Ensign Laurent_F Ensign
Ensign
Posted: โ€Ž2022-05-23 08:12 AM
In response to marc_akoto_AUTEM
2
7658
Thank you Marc !
This tutorial will for sure help a lot users (at least the one speaking french, and the ones that know the automatic translated subtitles in Youtube).
FYI: Schneider Electric has also launched in 2022 its own 3D Digital Twin Software: EcoStruxure Machine Expert Twin.
  • 3d
  • digital twin
MaxenceProuvost
Ensign MaxenceProuvost Ensign
Ensign
Posted: โ€Ž2022-10-14 12:36 AM
In response to Laurent_F
1
5197
Hello @marc_akoto_AUTEM , now you can make the same with our Digital Twin ! ๐Ÿ™‚
https://www.se.com/ww/en/product-range/97196554-ecostruxure-machine-expert-twin/#overview
marc_akoto_AUTEM
Ensign
Posted: โ€Ž2022-10-17 03:07 AM
In response to MaxenceProuvost
๐Ÿš€@MaxenceProuvost
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
