Red exclamation mark in installed Library EcoStruxure Automation Expert
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Red exclamation mark in installed Library EcoStruxure Automation Expert
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Francisco1232
Francisco1232
Cadet
Posted: ‎2024-08-15 07:04 AM
1026
Hi everyone!
I have a problem in my project in EcoStruxure Automation Expert software (I'm a begginer in working with this software). I want to connect to a controller (axc-f-2152) from Phoenix Contact.
For this I have downloaded an IO driver library for developing applications using the 61499 runtime application on the PLCnext platform. The name of the library is PhoenixContact.Standard.
I have EcoStruxure Automation Expert v23.1 and the library I have installed is v22.1.0.5. When I install the library, there is a red exclamation mark next to the name of the library. Maybe is there a problem with the installation? Because I have had a difficult time trying to connect to the controller in the EcoStruxure Automation Expert software. I can't add my device in logical devices.
The library doesn't have a new version. Maybe do I have to install a previous version of EcoStruxure Automation Expert software for it to work?
Here is a image of the installed library:
If someone could help me with some advise I would be really thankful.
Kind regards,
Francisco.
  • Hardware platforms
  • Hardware-Software decoupling
jeromerives
Ensign jeromerives Ensign
Ensign
Posted: ‎2024-08-19 05:59 AM
990
exclamation mark = Unofficial version (selected when you create the librairie)
try with V23.0 version
Francisco1232
Francisco1232
Cadet
Posted: ‎2024-08-20 12:43 AM
In response to jeromerives
Hi @jeromerives,
Thank you very much for your answer.
For the runtime I have already downloaded the 23.0 version as you recommended. But I haven´t found a new version for the UAO Hardware CAT Library, it is in this link: https://www.plcnextstore.com/eu/app/615
I have downloaded both, the runtime in the PLCnext controller and the library in the Ecostruxure Automation Expert software.
Do you think a solution could be to download EcoStruxure Automation Expert v22.
Do you know if there is a way to roll back the application to version 22 or maybe do you know where I can find that version?
Thanks in advance!,
Francisco.
jeromerives
Ensign
Posted: ‎2024-08-20 06:08 AM
I have never used Phoenix contact products so I think the best is to contact Phoenix Contact developer to find out if a V23 version exists.
If not, in EAE v23.1, try to change the project library references to V22.1 to have the runtime.base V22.1.
For the libraries or EAE V22.1, contact your Schneider Electric representative or the local Customer Care Centre
