Offset 875EC
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Send InviteCancel
Posted: 2024-08-2212:17 AM
Offset 875EC
I have an 875EC transmitter with an 871EC sensor at a range of 0 to 11.20 mS/cm. When performing the calibration (Bench 2 Point), the equipment takes the values for calibration. But when placing it for measurement, maintain an Offset of 2 mS/cm, instead of 11.20 it indicates 13.20 mS/cm. What is the problem or is it a configuration error.
