POU, Data Type & Function utilization in EAE application
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • POU, Data Type & Function utilization in EAE application
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
anandbpillai
Ensign anandbpillai Ensign
Ensign
Posted: ‎2021-10-11 09:22 PM . Last Modified: ‎2023-07-28 02:24 AM
2497
There is POU, Data Type & Function available in the EAE application but not sure what is the exact purpose and how it is to be mapped in any application.
The help also is not that useful for this topics.
Pls provide any support or document reference for this.
PatrickJouvenel
Crewman PatrickJouvenel Crewman
Crewman
Posted: ‎2021-11-10 06:54 AM
In response to anandbpillai
for Datatype is quite straightforward:
- enumeration
TYPE DataType3 : (item1,item2,item3);END_TYPE
- alias
TYPE DataType2 : BOOL; END_TYPE
-struct
TYPE DataType1 : STRUCT
item1  : BOOL;
item2  : REAL;
item3  : STRING;
 END_STRUCT;
END_TYPE
-array
TYPE DataType5 : ARRAY[0..4] OF BOOL;END_TYPE
-subranges
TYPE DataType4 : SINT(0..10);END_TYPE
All can be defined as types and then used in variable declarations (interfaces of cats, composites, basics...) or in your symlinks definition
Replies 4
TomRos
TomRos Schneider Alumni (Retired)
Posted: ‎2021-10-13 08:42 AM . Last Modified: ‎2021-10-15 10:36 AM
1
2475
The purpose of POU is to make use of IEC 61131 code.  In order to embed this code inside an IEC 61499 program you should add a PGM block inside the 1499 function block network and trigger the input event from any 1499 function block.  This input will activate the 1131 code.
If you have further questions on this topic please let us know.
Additionally, we are in the process of reviewing and improving the Help content, so I will bring this feedback into our review.
anandbpillai
Ensign
Posted: ‎2021-10-27 11:58 PM
2401
thank you for the reply. @TomRos
For POU it is ok.
what about Data Type & Function.
Also as you rightly said the help files needs more update for all of these.
PatrickJouvenel
Crewman
- enumeration
- alias
-struct
item1  : BOOL;
item2  : REAL;
item3  : STRING;
 END_STRUCT;
END_TYPE
-array
-subranges
JLux
JLux Cadet
Cadet
Posted: ‎2021-11-12 10:34 AM
In response to TomRos
Do you have an example using the PGM Bloc - Cant find it in any existing libraries
thx
