EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Posted: 2025-05-20 01:48 AM
Using softdPAC and trying to connect to it through OPC UA. The logfile says (image) certificate x509 missing and error -22 for opc ua stack initialization. Using v24.0 and softdPAC v24.0.24149.01. Can operate the physical I/O through EAE but not connecting to the OPC server. If testing as Local Test connecting to the opc server works. Tried reinstalling softdpac etc.
Posted: 2025-05-21 12:34 AM
Was using windows, but solved the problem, had to set userlevel to advanced to modify the OPC UA server security settings properly.
Posted: 2025-05-21 12:32 AM
Hi @Emil1 ,
Can you precise which hardware are you using ? Is that softdpac Windows or Softdpac Linux ?
