Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Posted: 2021-08-11 02:58 AM . Last Modified: 2023-07-28 02:24 AM
We have bought a new PLC (Model Modicon TM221M16T). When connected to laptop through mini-USB cable BMXXCAUSBH045, ecostruxure software detects the PLC & M221(usb) is listed in local devices section. But, when I try to log in, status window shows progress upto 86% and then stops. After sometime, it gives error advisory: "Communication detected error. Verify USB cable, Modbus driver parameters, controller connection or power supply."
Please suggest solution for successful login.
Posted: 2021-08-11 03:16 AM
I guess that you should redirect your question to EcoStruxure Machine Expert forum 👨💻👍
Posted: 2021-08-11 09:58 AM
Just to confirm, EcoStruxure Automation Expert currently supports the following controllers:
-M580d
-M251d
-ATVd
-Soft dPAC
