.How can a partner add value to Ecostruxture Automation Expert?
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • .How can a partner add value to Ecostruxture Automation Expert?
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-09-15 08:28 AM . Last Modified: ‎2023-07-28 02:26 AM
1393
Rodrigo G.
Industrial Automation Community manager
  • faq
Kaishi
Kaishi Schneider Alumni (Retired)
Posted: ‎2020-09-16 05:41 AM
We strongly believe that the IEC 61499 standard-based system will enable a "plug & produce" world where developers, SI's, and OEM's will encapsulate their knowhow/IP in reusable software component libraries. You can then use those software component libraries to generate business either by selling it directly or by using it to promote your services.
Kaishi
