.How can a partner add value to Ecostruxture Automation Expert?
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Send InviteCancel
Posted: 2020-09-1605:41 AM
We strongly believe that the IEC 61499 standard-based system will enable a "plug & produce" world where developers, SI's, and OEM's will encapsulate their knowhow/IP in reusable software component libraries. You can then use those software component libraries to generate business either by selling it directly or by using it to promote your services.
