Error: The instance is located on an address that isn't configured. : TestReal
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Error: The instance is located on an address that isn't configured. : TestReal
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Modicon M340
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
jhonut1
Crewman jhonut1
Crewman
Posted: ‎2023-02-01 05:35 AM . Last Modified: ‎2023-07-28 02:22 AM
3858
I have a BMX P342020 PLC programmed with Unity Pro XL V12.0
I want to associate an address to a real variable. When I do this, I get the error: "The instance is located on an address that isn't configured. : TestReal". I found on CPU configuration that %MF is desabled for CPU objects, but can be selected for I/O. The problem is that if I select all and close CPU configuration window, the settings are not saved. How could I solve the error?
Anil_Pandey
Ensign Anil_Pandey Ensign
Ensign
Posted: ‎2023-02-01 08:56 PM
3843
Hi Jhonut,
This Community is meant for EcoStruxure Automation Expert. I encourage you to drop your future queries in Industrial Automation Community if related to IDPAC product line.
Reply for your query:
For Modicon M340 PLCs, double-type instances of located data (%MD<i>, %KD<i>) or floating (%MF<i>, %KF<i>) are not available.
Use %MW address instead for Real data type.
Hope this helps.
jhonut1
Crewman jhonut1
Crewman
Posted: ‎2023-02-02 02:02 AM
In response to Anil_Pandey
3835
Thank you very much for replying! I can assign a %MW to a variable of type REAL and I get rid of the error. But my question is how could I associate a float value to %MW address?
I read two registers and convert them to real. If I associate %MW to a real, the value I get is not correct. Please see the attached photos!
Anil_Pandey
Ensign
Posted: ‎2023-02-02 11:35 PM
In response to jhonut1
Can you check by swapping Low and High word register addresses? If still facing issue, then raise a support ticket to customer care for detailed analysis.
