EcoStruxure Operator Terminal Expert Simulation connecting to Modbus
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • EcoStruxure Operator Terminal Expert Simulation connecting to Modbus
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Teksea-Johnny
Teksea-Johnny
Cadet
Posted: ‎2025-05-12 12:17 PM
1049
Hello to all
I'm developing some HMI using EOTE, and to increase my development time I'm trying to connect the simulator to my Modbus Server. It's a localhost connection. But I can't do this working. Is this possible? Or only using a device atached?
Bastian_Schmitz
Admiral
Posted: ‎2025-05-12 10:29 PM
1033
If your Modbus Server works with Modbus TCP it should work with 127.0.0.0 or local host. With which PLC do you want to connect? If your communication is Serial I don´t expecet that it will work.
Bastian_Schmitz
Admiral
1034
KarimBenameur
Ensign
Posted: ‎2025-05-12 11:44 PM
In response to Bastian_Schmitz
Agree with Bastian, Simulator is not intended to be used with remote IO as for that you should use a Soft dPAC Windows or a Soft dPAC Linux.
On serial agree again Soft dPAC is not yet supported Modbus RTU but it will be supported by Essential Edge 2.0 coming very soon and later by other iPCs.
Teksea-Johnny
Teksea-Johnny
Cadet
Posted: ‎2025-05-13 03:51 AM
I'm developing a HMIST6600, and we will read modbus TCP from a custom device, we are developing this. But while I'm at development time, I wanna to use a modbus Slave emulator at PC, only to speed up the things
