EAE OPC UA Communication with M580 dPAC and Aveva InTouch 2023 R2 SP1
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • EAE OPC UA Communication with M580 dPAC and Aveva InTouch 2023 R2 SP1
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Eyanto
Ensign Eyanto
Ensign
Posted: ‎2025-07-11 04:37 AM
806
Hi everybody.
Need some guidances on setting up EAE OPC UA communication with M580 dPAC and Aveva InTouch 2023 R2 SP1. Below the simplified architecture of our system.
IP Address Settings: -
  1. OPC Server - M580 dPAC : 192.168.1.1
  2. OPC Client - HMI Aveva InTouch : 192.168.1.150
We have configured I/O variables to support OPC UA communication, below is the snapshot of the exposed list.
Besides that, in the Properties pad of M580 dPAC we have done the followings: -
  • Runtime Configuration > Communication > OPCUA Server > Enable server > True
  • OPCUA Stack Configuration > Server configuration > Security > Secured
Kindly refer to attached pictures for more details.
We have deployed the configuration on M580 dPAC. Unfortunately, the OPC Client (HMI Aveva InTouch) still unable to connect to OPC UA Server. Kindly refer to Aveva OCMC OPCUA Setting picture attached for more details.
Appreciate for some guidances in solving this issue. Thank you so much.
mohamedriswan
Ensign
Posted: ‎2025-07-15 09:19 PM
1
775
Hi Eyanto,
Did you deployed the Device configuration in EAE? Also can you verify using UA Expert the data's are exposed?
mohamedriswan
Ensign
1
776
Hi Eyanto,
Eyanto
Ensign Eyanto
Ensign
Posted: ‎2025-07-16 06:20 PM
In response to mohamedriswan
Assalamualaikum @mohamedriswan,
Thank you for your reply. Under Deploy and Diagnostic tab, executed Device configuration > Deply Device Configuration. Now we got all exposed tagnames at Aveva OCMC OPCUA. Thanks again for the support.
