ETL import database
ETL - Extract Transform Load
EcoStruxure IT Advisor integrations for the advanced user
  • EcoStruxure IT Help Center
  • IT Advisor
  • ETL - Extract Transform Load
  • ETL import database
  • Mark as Read
  • ETL export database
  • ETL transformation management
EcoStruxure IT Support
Request Support
Back to ETL - Extract Transform Load
  • Mark as Read
ETL import database
Picard EcoStruxureIT
‎2020-04-06 07:56 AM
Last Updated: Sisko JLehr Sisko ‎2024-03-20 05:50 PM
The ETL import database is by its predefined schema providing an API to populated EcoStruxure IT Advisor with data.
The schema is graphically represented in the ETL Import Database Schema attached below.
Importing large amounts of data
When importing data, the affected rooms are locked and other changes cannot be done at the same
time. So if you are importing large amounts of data, please consider doing so when it affects as few users as possible.
From version 8.0.2 we have tried to minimize the effects of locking the affected rooms by locking less and for a shorter amount of time.
There is a lock in the staging database that you can set while performing changes. As long as the lock is set, IT Advisor will wait before synchronizing the data from the staging database.
Description of tables, relations and classifications
In the following section there is a distinction between tables and classifications.  Technically both are tables in the database, but conceptually there is a big difference.
Please make sure to understand the Database Information State for the ETL import database. The information state is important since it is used for "bookkeeping" of data in the database.
Tables are used to store information, whereas the classifications are used to classify the information which enables ITA to interpret and handle the information.
Classifications are "read-only" since they a closely coupled with a specific revision of IT Advisor.
Relations describe the way information is related.
Table: SCHEMA_VERSION
The SCHEMA_VERSION table contains only one record which is used to indicate the version of this database schema.
The current schema-version is 1.2.0, as can be seen in the overview found below.
Version
ITA Version
Description
1.0.0
Initial schema design for the ETL feature
1.2.0
ITA 9.0.5
Added asset table and support for asset network ports and connections
Table: CONFIGURATION_ITEM
The configuration item is the central entity in the ETL data model. Therefore the central table of the staging-database is the CONFIGURATION_ITEM table. The table is expected to hold every piece of datacenter equipment/entity, both physical or virtual, that can provide information or data to IT Advisor. Examples include, but is not limited to servers, temperature sensors,...
The last three fields are used for bookkeeping as described here.
CONFIGURATION_ITEM
Field
Data type
Description
Required
Sample data
ci_id
varchar(255)
Unique identifier of item (primary key).
Mandatory
"server_001"
cit_id
BigInt
Specifies the type of this item. The value is a foreign key to values in the CONFIGURATION_ITEM_TYPE table.
Mandatory
1
ci_name
varchar(255)
Name of the item.
Mandatory
"Server XYZ"
ci_barcode varchar(255) Barcode of the item. Optional "IT1234567890"
ci_location
varchar(255)
Location of item.
Optional
"Behind Rack A in aisle B"
ci_model_number
varchar(255)
Item model number.
Optional
"DL360"
ci_model_name
varchar(255)
Item model name.
Optional
"HP Proliant"
ci_serial_number
varchar(255)
Item serial number.
Optional
"KN20623BY9"
ci_manufacturer
varchar(255)
Manufacturer of item.
Optional
"HP"
ci_ip_address
varchar(255)
Main ip-address of item.
Optional
"192.168.1.75:8080/adminConsole.cgi"
ci_description
varchar(255)
Description of item.
Optional
"Honeypot in DMZ"
ci_fingerprint
varchar(255)
Some unique "fingerprint" of the item, that may make it easier to match with items in the ITA model.
Optional
state_flag
varchar(16)
Indicates the state of the information. See section on information state above
Mandatory
new, changed, deleted, synced
state_last_updated
long
Timestamp set by the external system whenever the information in the row/record is changed.
state_last_synchronized
long
Timestamp used by SWO to indicate when the row was last successfully read and synchronized.
When modeling a data center, configuration items often have a natural parent-child relationship with each other. As an example servers are placed in racks which are placed in rows in a room. These relation-ships are captured in a relation-table instead of directly on the configuration. This allows the configuration items to participate in multiple relations, and to model different type of relations.
Classification: CONFIGURATION_ITEM_TYPE
The term configuration item is very broad and can be used to describe just about anything in the data center. To make it possible to distinguish between different types of configuration items, they are classified with a configuration_item_type.
The configuration_item_type information is used in IT Advisor to decide how to store, represent and utilize the configuration item. The currently supported types are found in the table below.
ID
Name
Description
Unspecified
Type used if no other type matches.
1
SERVER
This type indicates, that the item should be handled as a server.
2
SENSOR
This type indicates, that the item should be handled as a sensor.
3
AC
4
BATTERY_MANAGER
5
BRANCH-CIRCUIT_MONITOR
6
CAMERA_POD
7
CCTV_POD
8
CHILLER
9
CONSOLE_PORT_SERVER
10
DC_RECTIFIER
11
ENVIRONMENT
12
GENERATOR
13
INFRASTRUXURE
14
KVM_SWITCH
15
NETBOTZ_WALL
16
NETBOTZ_RACK
17
NETBOTZ_ENCLOSURE
18
NETWORK_DEVICE
19
POWER_DISTRIBUTION
20
POWER_METER
21
RACK_ACCESS_DEVICE
22
RACK_MANAGER
23
RACK_POWER_DISTRIBUTION
24
SENSOR_POD
25
SHARED_DEVICE
26
SNMP_DEVICE
27
STATIC_TRANSFER_SWITCH
28
TRANSFER_SWITCH
29
UPS
30
FAN_MODULE
31
IO_CARD
32
PSU
33
UCS_CHASSIS
34
UCS_MANAGER
35
UCS_SERVER
36
BLADE
37 VIRTUAL_MACHINE
38 DESKTOP_COMPUTER
39 NETWORK_SWITCH
Table: CONFIGURATION_ITEM_PROPERTY
The configuration item has a basic set of properties that are used for genome matching and identification in the UI. If other properties needs to be handled, they are stored in the CONFIGURATION_ITEM_PROPERTY table together with a reference to the configuration item. Each configuration_item_property has a type to classify the property.
Field
Data type
Description
Required
Sample data
ci_id
varchar(255)
Unique identifier of item (foreignkey)
Mandatory
"server_001"
cip_name
varchar(255)
The name of the property
Mandatory
"servicetag"
cip_value
varchar(255)
Value of property
Mandatory
"KN20623BY9"
pt_id
BigInt
Specifies the type of this property. The value is a foreign key to values in the PROPERTY_TYPE table
Mandatory
1
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Note: this table has a complex unique primary key made up of (ci_id, cip_name)
Classification: PROPERTY_TYPE
The different types of configuration_item_property is classified using the values in the table below.
PROPERTY_TYPE
ID
Name
Description
Unspecified
Properties of this type are not handled by the system
1
TAG
This type indicates, that the property should be handled as a Tag
2
PROPERTY
This type indicates, that the property should be handled as a CustomProperty
3
GENOME
Not used. Reserved for future development.
4
ASSETPROPERTY
Use as a simple pass-through mechanism allowing for dynamic properties on configuration items
Depending on type, the properties are handled in slightly different ways. Properties of type TAG and PROPERTY are interpreted as Tags and Custom Properties and are automatically assigned to items in the ITA Data Model when configuration items are associated, they will not show up for configuration items that are not associated with items in the model.
Note
For tags: Currently it is not possible to create a new tag through ETL, the tags should be known by Operation before synchronizing with the staging database. Properties of type ASSETPROPERTY are set directly on the configuration items. They are passed through the synchronization system without interpretation, and show up on the configurations regardless of association.
Table: CONFIGURATION_ITEM_MEASUREMENT
Datapoints and Measurements are stored in the CONFIGURATION_ITEM_MEASUREMENT table with a reference to the configuration_item and the class of measurement.
Besides this, the measurements are further classified using unit and type. The measurement unit classification is used to ensure the correct magnitude of the measurement.
The class of a measurement specifies the overall type of measurement like, CPU utilization, voltage, current, temperature...
Measurements type is needed together with the interval_start and interval_end fields to distinguish between single measurements in space and time, minimum, average and maximum values over a time period.
Power and current values
For power measurements you have to provide both a peak power measurement and an average power measurement.
For current measurements you can only use peak measurement.
Field
Data type
Description
Required
Sample data
cim_id
varchar(255)
Mandatory
"measurement_001"
ci_id
varchar(255)
Specifies the item that this measurement is associated with. The value is a foreign key to values in the CONFIGURATION_ITEM table.
Mandatory
"server_1"
cim_subid
varchar(255)
A subid for the measurement which is used with branch circuit monitoring to distinguish between submodules.
Optional
"breaker_01"
cim_value
float
The "measured" value.
Optional
7.35
mu_id
BigInt
Specifies the unit of this measurement. The value is a foreign key to values in the MEASUREMENT_UNIT classification.
Optional
1
mc_id
BigInt
Specifies the class of this measurement. The value is a foreign key to values in the MEASUREMENT_CLASS  classification.
Optional
3
mt_id
BigInt
Specifies the type of this measurement. The value is a foreign key to values in the MEASUREMENT_TYPE classification.
Optional
2
cim_interval_starttime
long
Start time for the measurement
Optional
123400
cim_interval_endtime
long
End time for the measurement
Optional
123500
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Classification: MEASUREMENT_UNIT
This classification is used to ensure the correct labels and magnitudes of measurement when displayed and used in calculations inside IT Advisor.
MEASUREMENT_UNIT expresses the measurement unit of a measurement.
MEASUREMENT_UNIT
ID
Name
Description
Unknown
Unit less measurement or unit not known.
1
W
Watt
2
kW
Kilo Watt (1kW = 1000W)
3
MW
Mega Watt (1MW = 1000000W)
4
PCT
per cent
5
PML
per mille
6
B
Byte
7
KB
Kilobyte (1kB = 1024B)
8
MB
Megabyte (1Mb = 1024kB)
9
GB
Gigabyte (1GB = 1024MB)
10
TB
Terabyte (1TB = 1024GB)
11
PB
Petabyte (1PB = 1024TB)
12
EB
Exabyte (1EB = 1024PB)
13
K
Kelvin
14
F
Fahrenheit
15
C
Celsius
16
RPM
Revolutions per minute
17
MPS
Meter per second
18
Bar
Bar
19
Psi
Psi (pounds per square inch)
20
S
Second
21
Ms
Millisecond
22
Mys
Microsecond
23
Ns
Nanosecond
24
Bps
Bytes per second
25
Kbps
Kilobytes per second
26
Mbps
Megabytes per second
27
GBPS
Gigabytes per second
28
TBPS
Terabytes per second
29
V
Volt
30
KV
Kilo volt
31
A
Ampere
32
MA
Milliampere
33
Cfm
Cubic feet per minute
34
Gkg
Gram per kg
35
RH
Relative humidity
36
VA
Volt-ampere
37
Wh
Watt-hour – used for energy measurement (1000Wh = 3.6MJ)
38
kWh
Kilo Watt-hour = 1000Wh
39
MWh
Mega Watt-hour =1000kWh
40
VAh
Volt-ampere-hour – unit for apparent energy
41
kVAh
Kilo Volt-ampere-hour = 1000VAh
42
MVAh
Mega volt-ampere-hour = 1000kVAh
43
J
Joule
44
Unitless
Unitless measurement like factors – this is NOT the same as unknown
Classification: MEASUREMENT_CLASS
The MEASUREMENT_CLASS classification is used to indicate what is measured. The table below lists the different classes of measurements that is of interest to ITA.
Note: Most of these are included for future usage and are not used/interpreted in the current version of ETL Integration. The currently supported classes are highlighted.
MEASUREMENT_CLASS
ID
Name
Description
unspecified
Indicated that nothing is known about the measurement.
1
cpu_utilization
2
cpu_idle
3
cpu_wait
4
memory_usage
5
memory_swap
6
disk_io
7
disk_latency
8
net_io
9
power
You have to provide both a peak power measurement and an average power measurement.
10
power_single_phase
11
power_L1
12
power_L2
13
power_L3
14
current
Only PEAK_DAY and MAXIMUM measurement types are supported.
15
current_single_phase
16
current_L1
17
current_L2
18
current_L3
19
voltage
20
voltage_single_phase
21
voltage_L1
22
voltage_L2
23
voltage_L3
24
temperature_inlet
25
temperature_outlet
26
temperature_ambient
27
humidity_absolute
28
humidity_relative
29
pressure
30
velocity
31
time
32
time_elapsed
33
time_remaining
34
frequency
35
flow
36
volume
37
apparent power
Note: The value is imported as a sensor, and is not used in any calculations, tooltips, etc.
38
active power
39
power factor
40
temperature delta
Classification: MEASUREMENT_TYPE
The MEASUREMENT_TYPE classification is used to indicate how a measurement was made, with regards to the factor of time. MINIMUM, MAXIMUM and AVERAGE classes are used to indicate that the measured value is aggregated over a period of time, whereas POINT classes are single measurements at a given point in time.
The time interval or point in time is specified in the CONFIGURATION_ITEM_MEASUREMENT table as cim_interval_starttime and cim_interval_endtime.
Note: Not all measurement types are supported for all measurement classes. The currently supported classes are highlighted.
MEASUREMENT_TYPE
ID
Name
Description
Unspecified
1
MINIMUM
Indicates that the measurement is the smallest observed value in the given time interval
2
MAXIMUM
Indicates that the measurement is the largest observed value in the given time interval
3
AVERAGE
Indicates that the measurement is the average value over the given time interval
4
POINT
Indicates that the measurement is a point measurement at a specific point in time
5 AVERAGE_DAY
Indicates that the measurement is the average value for the day. This value is read by ITA in the same way as DCE data and is more useful to the ITA server than AVERAGE
6 PEAK_DAY
Indicates that the measurement is the largest observed value for the day. This value is read by ITA in the same way as DCE data and is more useful to the ITA server than MAXIMUM
Table: BREAKER_PANEL_MEASUREMENT
The breaker_panel_measurement table can be used for integrating power measurement from a branch-circuit monitoring system. You only need to specify either power or watts, but please note that there is no automatic conversion between watts and amps. In most cases if you have both the best option is to specify both.
Learn more about importing manual measurements
Field
Data type
Description
Match type
Sample data
id
varchar(255)
Unique identifier of the measurement (primary key)
Mandatory
"m_001"
ci_id
varchar(255)
Unique identifier of the item (which must have breaker panels) that this measurement originated on (foreignkey)
Mandatory
"pde_001"
panel_id
varchar(255)
Name of the breaker panel that have the measurement, this must match the panel in ITA
Mandatory
"Panel A"
circuit_number
INTEGER
Position on the breaker panel, this must match a circuit number on the given panel in ITA
Mandatory
5
power_phase
varchar(2)
Power phase of the measurement, only needed if multiple positions on the panel have the same circuit number
Optional
"L1", "L2" or "L3"
time
timestamp
When was the measurement made
Mandatory
 1476057600000
amps
double precision
The measurement in amps
Optional
 7.8
watts double precision The measurement in watts Optional 1250.0
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Table: ASSET
 Introduced in 9.0.5. Rows in this table represent rack-mounted equipment in the model directly, as opposed to CONFIGURATION_ITEMs representing external system Devices. This allows to add, update and delete equipment items.
ASSET
Field
Data type
Description
Match type
Sample data
asset_id
varchar(255)
Unique identifier of the asset (primary key)
Mandatory
"asset_01"
item_uuid
varchar(36)
Internal unique identifier of the asset in the model, assigned automatically by import logic or used to set up reference to existing equipment
Optional
"1a3ff992-a505-48fd-89bd-44c221331dc6"
asset_name
varchar(255)
Name of the asset
Optional
"Server A"
rack_name
varchar(255)
Name of the rack the asset should be added or looked for; rack name should be unique in the room
Mandatory
"Rack 1"
room_name
varchar(255)
Name of the room the asset belongs to; should be unique within the solution, or room_parent_location should be used to identify the correct room; as of now, storages are not supported
Mandatory
"Room 1"
varchar(255)
Used to find the correct room; if room_name is unique within the solution, this field is optional
Optional
"Location 1"
enclosure_name
varchar(255)
Name of the enclosure, if the row represents switch or blade with it
Optional
"Enclosure 1"
enclosure_slot
Bigint
Slot within the enclosure where switch or blade should be located; counted from left to right then rows from top to bottom
Optional
3
rack_mounting_position
Bigint
U-position or VU-position of the asset mounted in the rack; optional for switches and blades mounted in enclosures or if rack_mounting_type is one of rear_left or rear_right
Optional
1
rack_mounting_type
varchar(255)
How asset is mounted in the rack, see details below; ignored if the asset is mounted in enclosure, otherwise mandatory
Optional
"FRONT"
manufacturer
varchar(255)
Manufacturer used to lookup for correct model in Custom Catalog or Genome Library; optional if it is possible to find unique model by part_number and/or model_name
Optional
"HP"
model_name
varchar(255)
Model name that matches to Genome from Custom Catalog or Genome Library; optional if it is possible to find unique model by part_number
Optional
"HP Proliant"
part_number
varchar(255)
Part number that matches to Genome from Custom Catalog or Genome Library; optional if it is possible to find unique model by model_name
Optional
"DL360"
description
varchar(255)
Description of the asset
Optional
"Honeypot in DMZ"
barcode
varchar(255)
Barcode, must be unique within the solution
Optional
"IT0123456789"
serial_number
varchar(255)
Serial number of the asset
Optional
"ABC"
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
The rack_mounting_type is matched against the following values (ignoring case)
rack_mounting_type
Name
Description
FRONT
REAR
REAR_LEFT
Rack PDUs and ATSes only.
REAR_RIGHT
FRONT_LEFT
Only allowed in Racks with vertical u-positions.
FRONT_RIGHT
TOP
Only allowed in Racks with external top u-positions.
Available since ITA 9.2.1
BOTTOM
Only allowed in Racks with external bottom u-positions.
Table: ALARM
The ETL integration is not well suited to handling alarms due to the inherited latency in information-propagation through the system.
Nevertheless, it is possible to raise alarms on configuration items by adding them to the ALARM table.
ALARM
Field
Data type
Description
Match type
Sample data
alarm_id
varchar(255)
Unique identifier of alarm (primary key)
Mandatory
"alarm_01"
ci_id
varchar(255)
Unique identifier of the item that this alarm concerns (foreignkey)
Mandatory
"server_001"
alarm_severity
varchar(64)
Severity of alarm. Recognized values are critical, failure, error and warning. Not case sensitive
Optional
"Error"
alarm_state
varchar(64)
What is the state of the alarm. Recognized values are active and resolved . Not case sensitive
Optional
"Active"
alarm_message
varchar(255)
Text describing the problem. The text will be show as is, inside ITA
Optional
"Chiller malfunction – refrigerant pressure too high"
alarm_occured
timestamp
When was to alarm observed by the external system
Optional
alarm_resolved
timestamp
When was the alarm resolved on the external system
Optional
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
The alarm_severity is matched against the following values (ignoring case)
alarm_severity
Name
Description
critical
Critical alarm
failure
Incident in alarming system
If the severity does not match one of these values, the alarm is assumed to be pure informational.
Note: There is no way of resolving the alarms directly from IT Advisor.
The alarm_state is matched against the following values (ignoring case)
alarm_state
Name
Description
Active
Alarm is active
Resolved
Alarm is inactive
Table: CONFIGURATION_ITEM_RELATION
Relations between items are modeled using the CONFIGURATION_ITEM_RELATION table. Currently this is reserved for future use. To model a relation, both ends are referenced together with a classification of the relation.
Field
Date type
Description
Match Type
Sample data
cir_id
varchar(255)
Unique identifier of relation (primary key)
Mandatory
"cable_001"
ci_id_a
varchar(255)
Id of start point of this relation. This is a foreign key to the CONFIGURATION_ITEM table
Optional
"server_1"
ci_id_b
varchar(255)
Id of end point of this relation. This is a foreign key to the CONFIGURATION_ITEM table
Optional
"server_2"
rt_id
BigInt
Used to indicate the type of this relation. The value is a foreign key in the RELATION_TYPE classification.
Optional
state_flag
varchar(16)
state_last_updated
long
long
Classification: RELATION_TYPE
This classification is used to specify the kind of relation being modeled between two items.
RELATION_TYPE
ID
Name
Description
unspecified
Indicated that nothing is known about the relation.
1
a_inside_b
Reserved for future usage
2
b_inside a
3
a_powered_by_b
4
b_powered_by_a
5
a_connected_to_b
6
a_placed_left_of_b
7
a_placed_right_of_b
8
a_placed_in_front_of_b
9
a_placed_behind_b
10
a_placed_under_b
11
a_placed_above_b
12 a_vm_inside_b Reserved for future usage
Table: RELATION_PROPERTY
Information, besides the actual type of a relation, can be associated with the relation through RELATION_PROPERTY.
RELATION_PROPERTY
Field
Date type
Description
Match Type
Sample data
cir_id
varchar(255)
Reference to the CONFIGURATION_ITEM_RELATION
Mandatory
"cable_001"
rp_name
varchar(255)
The name of this property
Mandatory
"cable length"
rp_value
varchar(255)
The value of this property. The value is shown as is, and will not be interpreted or used in calculations.
Optional
"50m"
rpt_id
BigInt
Used to indicate the type of this relation property. The value is a foreign key in the RELATION_PROPERTY_TYPE classification.
Optional
state_flag
varchar(16)
state_last_updated
long
long
Note: this table has a complex unique primary key made up of (cir_id, rp_name)
As an example a simple parent-child relationship between a blade chassis and a blade may require a "placement"-property, where as a cable between two servers may need properties like cable-length, type, speed, etc.
As with the other entities in the staging-database, a RELATION_PROPERTY is classified by a type (rpt_id)
Classification: RELATION_PROPERTY_TYPE
Classification used for the type of relation-property.
RELATION_TYPE
ID
Name
Description
unspecified
Indicated that nothing is known about the relation property.
1
cable_routing
Used to classify cable routing information.
2 software_environment Used to specify the software environment of the relation
Note that the b_inside_a implies a child-parent relationship without the need of a specific relation-property. Therefore there is currently no explicit relation property type to capture information for this relation.
Table: RELATION_ENDPOINT_PROPERTY
In some cases, extra information about the relation endpoints are needed. One example is for network-connections where the endpoint properties are used to specify network port information.
Field
Date type
Description
Match Type
Sample data
cir_id
varchar(255)
Reference to a CONFIGURATION_ITEM_RELATION
Mandatory
"cable_001"
ci_id
varchar(255)
Mandatory
"server_1"
rep_name
varchar(255)
Mandatory
"port speed"
rep_value
varchar(255)
Optional
"1Gbps"
rept_id
BigInt
Used to indicate the type of this relation endpoint property. The value is a foreign key in the RELATION_ENDPOINT_PROPERTY_TYPE classification.
Optional
4
state_flag
varchar(16)
state_last_updated
long
long
Note: this table has a complex unique primary key made up of (cir_id, ci_id, rep_name)
Classification: RELATION_ENDPOINT_PROPERTY_TYPE
Used for classification of the endpoint properties. Currently the classification is not used, but prepared for future usage.
ID
Name
Description
unspecified
1
network_port_number
Not used
2
network_port_type
Not used
3
network_module_name
Not used
4
network_port_speed
Not used
5
rear_connected_port
Not used
Table: CHANGE_TICKET
Information about change tickets or work orders that should be imported are placed in this table. Note that the specified priority and status should be references to the CHANGE_TICKET_PRIORITY and CHANGE_TICKET_STATUS tables.
CHANGE_TICKET
Field
Data type
Description
Required
Sample data
ticket_id
varchar(32)
Mandatory
"ticket_001"
assignee
varchar(64)
Specifies who is assigned to the work order change ticket
Optional
"Mr Black"
comment
varchar(3000)
Used for comments on the work order change ticket
Optional
"Install OS"
due_date
BigInt
Specifies the due date of the work order change ticket
Optional
summary
varchar(128)
Used for summary of the work order change ticket
Optional
priority
Integer
Specifies the priority of the change ticket The value is a foreign key in the CHANGE_TICKET_PRIORITY  Mandatory
status_order
Integer
 Specifies the status of the change ticket The value is a foreign key in the CHANGE_TICKET_STATUS   Mandatory
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Table: CHANGE_TICKET_PRIORITY
The possible priority classifications for change tickets and work orders.
Field
Data type
Description
Required
Sample data
priority
Integer
Mandatory
priority_message
varchar(32)
  Mandatory
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Table: CHANGE_TICKET_STATUS
The possible status classifications for change tickets and work orders.
Field
Data type
Description
Required
Sample data
status_order
Integer
Mandatory
message
varchar(32)
  Mandatory
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Table: PORT_CONFIGURATION
Specifies network ports on equipment. The ports cannot overlap each other or with port configurations created in Operations client. The same rules as for the client apply.
For network speed the following units are supported: kbps, mbps, gbps, tbps, if no unit is specified it defaults to kbps, example speeds could be "100 kbps", "100 mbps" or "10 gbps".
PORT_CONFIGURATION
Field
Data type
Description
Required
Sample data
ci_id varchar(255) Reference to a CONFIGURATION_ITEM Mandatory "switch 001"
connector_type varchar(255) Connector type for the network port Mandatory "RJ45_REGULAR"
module_name varchar(255) Module name for the ports Mandatory "Module A"
start_port Integer Starting port number for the ports Mandatory  0
port_count Integer Number of ports in the configuration Mandatory  24
port_speed varchar(255) Network speed for the port configuration Mandatory "100 mbps"
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Table: ASSET_PORT_CONFIGURATION
Introduced in 9.0.5. Specifies network ports on equipment. This table is similar to PORT_CONFIGURATION and should be used to manage ports on equipment looked up using asset uuid or by names: asset name, enclosure, rack, room and location.
The ports cannot overlap each other or with port configurations created in Operations client. The same rules as for the client apply. For network speed the following units are supported: kbps, mbps, gbps, tbps, if no unit is specified it defaults to kbps, example speeds could be "100 kbps", "100 mbps" or "10 gbps".
Field
Data type
Description
Required
Sample data
id varchar(255) Identifier of port configuration Mandatory "port_001"
asset_item_uuid varchar(36) Internal unique identifier of the asset in the model Optional "1a3ff992-a505-48fd-89bd-44c221331dc6"
asset_name varchar(255) Asset name; mandatory if asset by-name lookup is used Optional "Server 1"
asset_enclosure varchar(255) Asset enclosure name Optional "Enclosure 1"
asset_rack varchar(255) Asset rack name; mandatory if asset by-name lookup is used Optional "Rack 1"
asset_room varchar(255) Asset room name; mandatory if asset by-name lookup is used Optional "Room 1"
asset_location varchar(255) Room parent location name; mandatory if asset by-name lookup is used and room name is not unique Optional "Floor plan 1"
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
The connector_type is matched against the following values (ignoring case)
connector_type
Name
Description
FIBER_REGULAR
FIBER_UPLINK
RJ45_REGULAR
RJ45_UPLINK
APC_LAN_REGULAR
APC_LAN_UPLINK
IP_KVM_UPLINK
IP_KVM_REGULAR
FIBER_SC_REGULAR
FIBER_SC_UPLINK
FIBER_LC_REGULAR
FIBER_LC_UPLINK
FIBER_ST_REGULAR
FIBER_ST_UPLINK
FIBER_MTRJ_REGULAR
FIBER_MTRJ_UPLINK
FIBER_FC_REGULAR
FIBER_FC_UPLINK
FIBER_MPO_MTP_REGULAR
FIBER_MPO_MTP_UPLINK
COAX_REGULAR
COAX_UPLINK
TERA_REGULAR
TERA_UPLINK
GG45_REGULAR
GG45_UPLINK
ARJ45_REGULAR
ARJ45_UPLINK
OTHER_REGULAR
OTHER_UPLINK
Table: NETWORK_CONNECTION
Network connections between both existing ports and ports that are just being created are specified here. The connections is not limited to only those created with ETL, but can also be to ports created in Operations using the client.
Since 9.0.5 it is possible to manage network connections using reference to ASSETs, so reference to CONFIGURATION_ITEMs is optional. Asset is looked up by using either from_asset_item_uuid or by finding equipment by names of: location, room, rack, enclosure (for blades and switches) and the asset name itself.
NETWORK_CONNECTION
Field
Data type
Description
Required
Sample data
id varchar(255) Unique identifier of the network connection (primary key) Mandatory "connection001"
from_id varchar(255) Reference to a CONFIGURATION_ITEM; mandatory if configuration_item lookup is used Optional "switch002"
from_asset_item_uuid varchar(36) Internal unique identifier of the asset in the model Optional "1a3ff992-a505-48fd-89bd-44c221331dc6"
from_asset_name varchar(255) Asset name; mandatory if asset by-name lookup is used Optional "Server 1"
from_asset_enclosure_name varchar(255) Asset enclosure name Optional "Enclosure 1"
from_asset_rack varchar(255) Asset rack name; mandatory if asset by-name lookup is used Optional "Rack 1"
from_asset_room varchar(255) Asset room name; mandatory if asset by-name lookup is used Optional "Room 1"
from_asset_location varchar(255) Room parent location name; mandatory if asset by-name lookup is used and room name is not unique Optional "Floor plan 1"
from_connector_type varchar(255) Connection type for the from item Mandatory "RJ45_REGULAR"
from_module_name varchar(255) Module name for the from item Mandatory "Module A"
from_port_number integer Port number for the from item Optional 17
is_from_patch_panel_rear integer Is the connection from the rear of a patch panel Optional 0
to_id varchar(255) Reference to a CONFIGURATION_ITEM; mandatory if configuration_item lookup is used Optional "server007"
to_asset_item_uuid varchar(36) Internal unique identifier of the asset in the model Optional "1a3ff992-a505-48fd-89bd-44c221331dc6"
to_asset_name varchar(255) Asset name; mandatory if asset by-name lookup is used Optional "Server 1"
to_asset_enclosure_name varchar(255) Asset enclosure name Optional "Enclosure 1"
to_asset_rack varchar(255) Asset rack name; mandatory if asset by-name lookup is used Optional "Rack 1"
to_asset_room varchar(255) Asset room name; mandatory if asset by-name lookup is used Optional "Room 1"
to_asset_location varchar(255) Room parent location name; mandatory if asset by-name lookup is used and room name is not unique Optional "Floor plan 1"
to_connector_type varchar(255) Connection type for the to item Mandatory "RJ45_REGULAR"
to_module_name varchar(255) Module name for the to item Mandatory "Module A"
to_port_number integer Port number for the to item Optional 1
is_to_patch_panel_rear integer Is the connection to the rear of a patch panel Optional 0
barcode varchar(255) Barcode for the connection Optional "87654321"
description varchar(255) Description for the connection Optional "Description for the connection"
install_date timestamp Installation date for the connection Optional "2015-01-31"
length double precision Length of the network cable Optional 100.0
manufacturer varchar(255) Manufacturer of the network cable Optional "Network Cable Manufacturer"
model_name varchar(255) Model name for the network cable Optional
name varchar (255) Name for the network cable (if relevant) Optional
part_number varchar (255) Part number for the network cable Optional
serial_number varchar (255) Serial number for the network cable Optional "12345678"
state_flag
varchar(16)
Mandatory
state_last_updated
long
long
Table: CABLE_TYPE
When importing network connection you can specify cable types for the connections. The cable type should match a cable type already specified in ITA.
CABLE_TYPE
Field
Data type
Description
Required
Sample data
id varchar(255) Unique identifier for the cable type (primary key). Mandatory
"cable_type_001"
description varchar(255) Description of the the type of cable.   "KVM cable"
blue
SMALLINT
The blue part of the RGB color for the cable type.   255
green
SMALLINT
The green part of the RGB color for the cable type.
255
red
SMALLINT The red part of the RGB color for the cable type.
255
Table: SYSTEM_LOCK
Holds a single row with value SYSTEM_LOCK for column lock_name. The ETL jobs lock on this rows when an import starts. You can create an exclusive lock on the row to prevent import from running while staging database is being updated.
