Schneider Electric Device IP Configuration Wizard
Download
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Device IP Configuration
  • Download
  • Schneider Electric Device IP Configuration Wizard
NMC Support
Request Support
Back to Download
Commander CDiggin Commander
‎2024-06-11 05:51 AM
What is the Device IP Configuration Wizard?
The Device IP Configuration Wizard is a Windows application designed specifically to remotely configure the basic TCP/IP settings of Network Management Cards. The Wizard runs on Windows® Server 2012, Windows Server 2016, Windows Server 2019, Windows 8.1, and Windows 10. This utility is for IPv4 only.
NOTE: For NMC3 firmware v1.x, and NMC2 firmware v6.8.0 and higher:
  • The Device IP Configuration Utility only supports the discovery of unassigned devices.
  • You cannot search for assigned devices already on the network using an IP range unless you enable SNMPv1 and set the Community Name to “public”. For more information on SNMPv1, see the necessary NMC user guides available on the APC Website.
  • When the NMC IP address settings are configured, to access the NMC Web UI in a browser, you must update the URL from http to https.
How to Download the Device IP Configuration Wizard
The Wizard is available as a free download:
  1. Go to the APC Website.
  2. In the search bar at the top of the page, type "Network Management Device IP Configuration Wizard Download"
  3. From the panel at the top, navigate to Software.
  4. From the list, select Network Management Card Device IP Configuration Wizard Utility v5.0.4.
  5. Click the Download button.
