Choose Devices display
DCE notification policies
Send InviteCancel
Select the devices that will be part of a new or existing notification policy.
You checkmark the device groups or devices in the navigation tree to add all the alarms reported by the devices for that selection to the notification policy. You can then modify the configurations for individual device alarms in the Device Alarm Configuration view.
Note
All the devices monitored by the Data Center Expert server are added to the Default notification policy at device discovery.
Note
You must click OK in the "Choose Devices" display, and the "Create or Edit Notification Policy" display to apply your changes.
You can use the search feature to do the following:
Type text in the Search field to filter the navigation tree or the thresholds list. You can broaden or narrow your search using the Boolean operators AND, OR and NOT. Only items that contain the text you specify in the Search field are displayed. When the results of a search are displayed, the background of the search field is shaded. When you clear the Search field, the background shading is removed and all items are displayed.
Note
Search fields support the Boolean operators AND, OR, and NOT only.
