DCE update path
DCE downloads
  • EcoStruxure IT Help Center
  • DCE downloads
  • DCE update path
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to DCE downloads
  • Mark as Read
DCE update path
Picard EcoStruxureIT
‎2020-03-14 02:38 AM
Last Updated: Sisko JLehr Sisko ‎2025-09-22 04:33 AM
Want to install or update to the latest version of DCE?
Download links are now available to customers with valid software support contracts on EcoStruxure IT Entitlements.
Log in and then click Software Updates. More information...
If the DCE update files are not available in EcoStruxure IT Entitlements, contact your local technical support to verify your support contract and get access to the update file(s) you need.
Go to http://www.apc.com/support/contact/index.cfm and select your country/region.
DCE version
 Path to update
 9.0.0  Latest version
 8.3.0
 8.3.0 > 9.0.0
The update from 8.3.0 to 9.0.0 will transition your license management into mySchneider Software Management.
Contact customer support to assist you with migrating your DCE licenses to 9.0.0.
See the release notes
 8.2.0  8.2.0 > 8.3.0
The update from 8.2.0 to 8.3.0 requires that you install a new certificate before you install the software update.
 8.1.1  8.1.1 > 8.2.0 > 8.3.0
 8.1.0  8.1.0 > 8.1.1 > 8.2.0 > 8.3.0
  There is an issue in DCE 8.1.0 where non-admin users cannot access dashboards and widgets.
 8.0.0  8.0.0 > 8.1.1 > 8.2.0 > 8.3.0
 7.9.3  8.0.0 > 8.1.1 > 8.2.0 > 8.3.0
 7.9.2  7.9.3 > 8.0.0 > 8.1.1 > 8.2.0 > 8.3.0
 7.9.1  7.9.2 > 7.9.3 > 8.0.0 > 8.1.1 > 8.2.0 > 8.3.0
 7.9.0  7.9.1 > 7.9.2 > 7.9.3 > 8.0.0 > 8.1.1 > 8.2.0 > 8.3.0
 7.8.1
 7.9.0 > 7.9.1 > 7.9.2 > 7.9.3 > 8.0.0 > 8.1.1 > 8.2.0 > 8.3.0
 See Complete upgrade process for DCE 7.9.0
The DCE 7.9.0 release updates the server operating system to Rocky Linux 8.4. The upgrade from DCE 7.8.1 requires a fresh install of the software or a new VM.
DCE 7.9.0 does not support server appliances (AP9465, AP9470, and AP9475) manufactured before 2012.
Data Center Expert 7.9.0 server hardware requirements
For older DCE versions, contact your local technical support
100% helpful (4/4)
