EcoStruxure IT Advisor (9.x) Additional Courses
Course catalog
Send InviteCancel
EcoStruxure IT Advisor (9.x): + Capacity (for Users)
In this add-on course for EcoStruxure IT Advisor users, you will gain an understanding of Capacity, and how to use it to do your job, including the definitions of Redundancy, the principles behind the IT Advisor Power calculations, and the different methods for obtaining a device’s power consumption.
Specifically, this hands-on training covers how to:
Map the entire Power Path of devices from their source.
Configure Capacity settings for your IT devices.
Use Tool Tips and Impact Analysis.
Use Tags and Asset Provisioning to organize your equipment.
Install and connect Network equipment.
And much more
EcoStruxure IT Advisor (9.x): Administrator Course
In this add-on course for EcoStruxure IT Advisor Administrator users, you are guided through the process to install and configure the IT Advisor server and work hands-on in the training environment.
Build a virtual machine for IT Advisor
Install IT Advisor on the server
Use Webmin for server management
Download and install the desktop client
Perform basic server settings
Work on external connectivity for IT Advisor and API configuration
Configure users and groups
Create colo tenant users
EcoStruxure IT Advisor (9.5): Sustainability Dashboard
In this add-on course for EcoStruxure IT Advisor Administrator users, you are guided through the process to configure a Sustainability Dashboard view in the IT Advisor web client.
You will use the Energy Efficiency system configuration in a realistic secure environment.
Configure a data center power layout in IT Advisor
Configure an energy system to document key sustainability metrics:
Water usage (WUE)
Power Usage Effectiveness (PUE)
Carbon Usage Effectiveness (CUE)
Renewable Energy Factor (REF)
You will be guided to relevant sources of additional information.
Please contact your local sales representative for information about purchasing eLearning credits:
EcoStruxure IT eLearning 1000 credits:SWEL1000-Digi
