www.ccontrols.com ARCnet interface card now obsolete.
  • www.ccontrols.com ARCnet interface card now obsolete.
  • sesa119747
    sesa119747
  • sesa124503
    sesa124503
‎2018-09-06 02:30 PM
Replacement part for an obsolete part.
The VisiSat 2.1 engineering guide makes reference as follows: -
ARCNET Cards ARCNET cards with a PCI or PCMCIA interface are supported.
You can obtain these cards from Contemporary Controls (www.ccontrols.com) using the following order numbers:
For the PCI Card use either PCI20-485 or PCI20U-485 depending on which type of PCI slot the computer's motherboard supports. For PCMCIA use PCM20H-485.
Use an MN50-MI-ARC
  • Satchwell MicroNet
Tags (3)
  • 3793
  • modules
  • network
