"You need to enable JavaScript in your web browser to be able to use Building Operation" message is displayed when accessing EBO WebStation
  • "You need to enable JavaScript in your web browser to be able to use Building Operation" message is displayed when accessing ...
  • CraigEl
    CraigEl
Administrator CraigEl Administrator
‎2023-10-23 03:54 PM
on ‎2023-10-23 03:54 PM
"You need to enable JavaScript in your web browser to be able to use Building Operation" message is displayed in the browser window when accessing EBO WebStation using the URL "https://<IP>/login/login.html"
Building Operation Webstation 5.0.3 and later
In order to bypass automatic guest account login, some sites have used https://<IP>/login/login.html as a direct URL to the login page. In EBO 5.0.3 this direct URL has been changed to "https://<IP>/login.html" to allow PCT 2.0 to operate correctly.
Use the new "https://<IP>/login.html" URL to bypass automatic guest account login and update any saved browser bookmarks.
  • CraigEllis23
0% helpful (0/2)
