"Unable to connect to SQL Server: (local)\TACVISTA ([0] Cannot generate SSPI context)" error on Vista 5.1.2 installation
  • "Unable to connect to SQL Server: (local)\TACVISTA ([0] Cannot generate SSPI context)" error on Vista 5.1.2 installation
  • Anonymous user
‎2018-09-06 02:35 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-05-28 06:53 AM
Trying to upgrade to Vista 5.1.2 but the following error is displayed and the application will not install:
TAC Vista
Vista 5.1.2 Server/Workstation Installation
When you first run the Vista 5.1.2 file it should uninstall previous versions of Vista, which it does but it does not uninstall the hot fixes.
  1. Uninstall the Vista hot fixes through the add/remove programs in the control panel
  2. Run the TACVistaServer512 file again.
  • 3552
